Casio FX-300MS Calculator Logo
Posted on Apr 13, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I am using my Casio fx-300MS and have somehow gotten into the display where it puts my answers in exponential form; 5+5 = 1.0 exp10 to the 1. How do I return to getting my answers in standard form?
Anonymous
Level 2:
  • Expert 45 Answers
  • Posted on Apr 13, 2011
Anonymous
Expert
Level 2:
Answers
45
Questions
0
Helped
61256
Points
244
Display Format
To change the exponential display format, press the [MODE] key 3 times.
Fixed number of decimal places:
Press 1: Scientific Notation: 0
Press 2: SCI: 0
Press 3: NORM
You will then be prompted for NORM 1 or NORM 2. CHOOSE NORM 1
To return the calculation mode and setup to the initial defaults, press [SHIFT] [CLR] [2]
[=]. This will return the calculator to the following settings:
Calculation mode COMP
Angle unit Deg
Exponential display format Norm 1
Fraction display format a b/c
Decimal point character Dot
Percentage Calculations
Logarithm
The Casio FX-300MS does not provide base 2 logarithms as a single key operation. However, you can use the natural logarithm (ln, base e = 2.7182818...) and the formula
log2 ( x ) = ln( x ) / ln( 2 )
To calculate the base 2 logarithm of 16, key in
[ln] 16 [/] [ln] 2 [=]
and get displayed the correct answer 4.
The same simple formula also works for any other base, and actually for any other logarithms provided by your calculator. The FX-300MS also provides a logarithm to base 10 (lg). You could also
type
[lg] 16 [/] [lg] 2 [=] to get the solution to the problem above, or
[lg] 25 [/] [lg] 5 [=] to get the base 5 logarithm of 25.
How do you do exponential functions
Look for a key marked LN. Use SHIFT LN to access the exponential function. To enter the negative exponent use the change sign key (-) followed by 7. Press EXE/= to get the result.
2helpful
How to get answer in exponential form in fx-82ES
Press SHIFT MODE 7 then specify the number of digits you want after the decimal point.
How do you do an antilog problem on a casio fx-300?
For common logs (logs in base 10) use the 10^x function : Press [SHIFT] [Log] to access it.
For natural logs, use the exponential function. Press [SHIFT][ln] to access it.
6helpful
How to use antilog by casio fx-82es
The inverse of the log function is the function 10^
antilogarithm of (x)=10^(x)
The function shares the same physical key as the [LOG] function. To access it you press [SHIFT][LOG].
The antilogarithm of the natural log [LN] is the exponential function [e^x]. It shares the same physical key with the [LN] function. To access it press [SHIFT][LN]
1helpful
I am tutoring a student who uses the Casio fx-300MS. A problem required that he raise (-2) to the 4th power, and the calculator indicated the answer was -16. I know that the answer should be a positive 16,...
Enclose any negative number between parentheses before squaring.
If you enter -4^2, where - is the negation, the result will be -16 because of the priority rules: exponentiation (power) has priority over negation.
If you enter (-4)^2 the result will be 16, because parentheses have priority over the squaring: the 4 is negated then the result is squared.
1helpful
Fractions
there is a A b/c button. This is the button use to enter fractions. so 4/3 would be entered as 4 |A b/c| 3
If you want to have the answers in fractions as well, then I believe you hit more a few times. And then there should be a display option, in the display option, there should be a b/c. This will show your answers in fractions. Hope it helps
12helpful
I need to find the antilog to -6.80 on a casioi fx-300ms calculat
Alot of people have this doubt, so I might as well make it clear.
Press the 10^x button (while pressing SHIFT, of course; it's exactly above the LOG button) followed by the number whose antilog you desire.
Example :
Let's say we need antilog(-6.8),
1. Press SHIFT, followed by LOG (i.e 10^x); this'll display a 10 on the screen;
2. Type in -6.8;
3. Press "=";
4. This'll display 1.584893192x10^-7 as the solution, which is correct!
5. Bye, lol :P
Top Casio Office Equipment & Supplies Experts
k24674
Arnie Burke
Arnie Burke
Ngoro
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
