Hotpoint 23 in. BF50 Built-in Dishwasher Logo
Posted on Apr 13, 2011
The small plastic lever which opens the door of my BF50 needs replacing. My supplier needs the code no. for ordering purposes. Can you supply this please?
1 Related Answer
Anonymous
  • 351 Answers
  • Posted on Jun 26, 2009
SOURCE: Need replacement part for front dryer door sensor - broken
i sell parts online you can visit whirlpoolpartssurplus.com and get the phone number off there and i can order it for you
2answers
"Door is open. Close it" on screen -- I can't find any latch that isn't clicking into place, all doors are closed. Printer won't work.
A notch or little pin on one of the door (trays) that must fitting against a microswitch or a simple brass-blade contact under the hood of the tray or door or sometimes even by a ldr light detecting resistor.
Di470 error code c0210
Image Transfer/Paper Separator Corona charge leak detected and replace the
open front door pull main lever down and remove the small assy. with a small handel sticking out, replace the two very thin wires and the two end parts normally white try this site for parts as a start
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
ask for corona wires and corona housing end parts worse cast the HV power supply went bad
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
The plastic door piece which opens the door has broken off. ( I did not know that i had to wait 2 minutes after it finished and it snapped off.) i am wondering what i have to replace, the part serial...
Sorry but this forum does not supply parts direct; it's just made up of ordinary guys and gals, probably at home, with experience of addressing problems and giving guidance for free on the web ;-0)
Spares Suppliers
You will need to type into your search engine/web browser '(make) washer spares' and you should be presented with a number of sources from which you can order. During the process you will be asked for the actual model number.
Alternately you could try telephone directories for spares suppliers but I would think the former would be more successful.
Good luck,
John C
3helpful
My k750i joystick broke off
Hi. You will need to open the phone in order to replace it, providing you have a spare joustick button ready. I assume you mean the navigate button, and not the underlying microswitch attached to the curcuit board.
To open the phone remove battery, memory card and sim. Then unscrew the two torx head screws at the bottom. Gently pry open the front cover along the edges, using a thin and preferrably blunt object of plastic to avoid damage and marks. (you can find special tools like for this purpose, sold from mobile phone spare parts suppliers)
Gently lift off keypad, and lift up the keypad electronic borad to access your broken joystick. Put the new in place and reverse to close. Be careful, a mobile phones's "inners" is very delicate. Do not overtighten the small screws.
See attached pictures for more information.
If you need more details, leave a comment
1helpful
Red light blinking 3 times. Book says problem with lamp door. We replaced the lamp and the door is closed properly, but the tv will not turn on.
Lots of these sets had a issue with the door. There are two things to do to confirm if it is your problem:
1.) With the set unplugged remove the door and examine it sideways; you are looking to see if it is bowed or warped slightly.
2.) The door has a plastic peg on the back that engages a small lever; The lever connects to a safety switch--if the door is warped and that peg does not engage the lever the set will detect "door not properly closed" and a error code will be the red light on front blinking a certain number of times and pausing and repeating this error code.
The way to finally confirm this (I have done this myself) is to engage the lever (usually blue in color and not large) with something plastic or even a wood match stick.
Just do this long enough to see if the lamp comes on. IF THE SET WORKS THE DOOR NEEDS TO BE REPLACED.
Do not operate the set with the door removed or replace the front grill as the open lamp door could also melt the front grill.
DO NOT LOOK DIRECTLY IN THE OPENING IF THE LAMP COMES ON AS IT CAN DAMAGE YOUR EYES WITH THE BRIGHT LIGHT.
If you find it is the lamp door confirm the actual model number and I will get you a part number and where to find it at. Several vendors on Ebay2_bing.gif sell OEM replacement doors for most of these sets.
Let me know what you find and I am here to help you.
SD TECH
Need new plastic primer for multi purpose strimmer
any good small engins shor should have tthem all both walbro and zama you nrrd to know the bdand and modl of thr m schine that needs ij
3helpful
Keep getting an error message "202 Paper Jam Open Rear Door", cannot clear the message. We ordered a maintenace kit maybe 3 months ago.
If you can't see any paper stuck inside the printer when you open the rear door or when you remove the toner cartridge, the rear paper flag is either stuck or broken.
The flag is a small piece of plastic which sits at the rear of the fuser and as the paper exits the fuser it pushes the flag down. The easiest way to see this is to remove the rear door then the rear cover (two screws).
If it's broken you'll require a replacement fuser (i don't think you can get the part separtely), but if you have recently installed a maintenance kit, i would contact the supplier and ask for a replacement.
"Door is Open" shows on the screen. Copier does not work.
hii.first of all check door is closed properly .see inside of door there is a small plastic lever which press door switch.may be this lever is broken .otherwise switch is not working properly .check it and replace this.
do not forget torate the solution
MIAN AKHLAQ
2helpful
Door Latch does not open door
I threw caution to the winds and removed the outer panel of the appliance. The plastic latching handle practically fell out--it was broken. Called all local parts suppliers--none had any parts in stock for this dishwasher. Called the manufacturer, who had a part listed on his computer at a distant location. Ordered it, paid for it, and was assured the part would be received within 2 days. Incidentally, you can't order just a replacement latching handle. It is included as part of a component.
Top Hotpoint Dishwashers Experts
Mike Cairns
Mike Cairns
Paul Carew
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
