What version of the typing program do you have? You have a few choices, depending on what OS runs the version you have.
If the program ran under Vista or XP (version 20 lists Vista compatibility), the compatibility mode is likely to work. For this, right click on the installer. Then choose Properties and then the Compatibility tab. Turn on Run program as Compatible with the appropriate OS. Then right click again on the installer and choose Run as Administrator. Then check if the program itself is running in the compatibility mode by right clicking again and choosing Properties.
If the compatibility mode doesn't work (for older versions of the software), you can use a computer (virtual, dual-boot, or true second machine) with an older version of Windows installed. If you have Win7 Pro or Ultimate, you can create a virtual XP computer for free. Download and install Virtual PC and XP mode from Microsoft. Install them in order. Then install the XP software on the virtual computer and it will work. (Other virtual computer programs are Parallels and VMWare.) All of the other options will require a licensed version of the older Windows OS. Please note that the virtual computer can't share files directly with the main computer. You'll need to save files to external or removable media (optical media or flash drive, for example) to share them.
Your final option is to upgrade to the current version. The 25th Anniversary edition runs under Windows 7. Other editions are not listed as compatible at the Broderbund site. You can try the Microsoft Windows 7 Compatibility Center for more information on tested software. My ISP is slow to connect to the site.
I hope this helps.
I want mavis teaches typing 15 free download but i can't
