Here is a diagram/picture with a description -
1 15Aamp Dome lights - Power mirror 2 door -Radio Memory
2 6Aamp C.B. Front washer/Wiper
3 No Use
4 15Amp Stoplamps 4 Way flashers
5 15Amp Back up lamps DRL - Canadian - Rear defroster Turn signals, Turn indicators
6 10Amp Speed Control
7 15Amp Cluster warning lamps
8 20Amp Horns
9 10Amp Air conditioner switches Clutch coil
10 15Amp Parking/Licence plate lights Trailer tow
11 15Amp Radio - switched - power
12 20Amp C.B. Cigarette lighter Flash to pass
13 10Amp Instrument panel illumination
14 30Amp C.B. Power windows
15 10Amp ABS module
16 20Amp Premium radio amplifier
17 15Amp Rear wiper/washer
18 15Amp Heated exaust gas oxygen - HEGO
Regards,
Tony
SOURCE: fuse box diagram
Here you go. Start on page 181.
http://www.motorcraftservice.com/pubs/content/~WOXEXP/~MUS~LEN/42/99expog1e.pdf
SOURCE: I need a fuse box diagram for a 2003 Ford Explorer
I believe that this is what you are looking for.....
Fuse and relay locations--2nd generation power distribution box Layout-
I think this is a good sticky candidate--
Fuses are listed here
* = maxi fuse
1*=50A I/P fuse panel
2*=40A blower motor relay
3*= 50A 4 wheel ABS module
4*=20a Main light switch-Instrument cluster
5*=50A Ignition switch, starter relay
6*=20A Transfer case relay
7*= NOT USED
8*=20A Auto Ride Control Switch/on off switch
9*=40A Auto Ride Control relay
10*=30A PCM power relay
mini fuses
1=10A A/C relay
2=20A Aux power point
3= not used
4=15A Fog lamps-Daytime lamps
5=10A Air Bag diagnostic monitor
6=10A Powertrain Control Module (PCM)
7=30A 4WABS module
8=30A PCM relay
9=20A Fuel Pump relay and RAP module
10= 15A Horn relay
11=15A Park Lamp relay-Main Light Switch
12=30A Main light switch--Multi Function switch
13=15A Heated O2 sensors, EGR Vacuum Regulator, EVR solenoid,Camshaft position (CMP) Sensor,
Cannister Vent Solenoid, A4LD Auto Transmission
14=30A Generator-Voltage regulator
Interior fuse panel (mini fuses)
1=7.5A Power mirror switch
2=7.5A Blower motor relay,PAD module,Air Bag diagnostic monitor
3=7.5A Trailer tow connector
4=10A Left headlamp
5=10A Data link connector (DLC)
6=7.5A Air bag diagnostic monitor, Blower motor relay, Passive deactivation Module (PAD)
7=7.5A Trailer Tow connector
8=10A Right headlamp, Daytime running lamps (DRL) module, Foglight relay
9=7.5A Stop Lamp switch
10= 7.5A Speed control-amplifier assembly,Brake pressure switch, Generic electronoc Module (GEM)
Shift lock actuator, Blend door actuator, Main light switch, RABS resistor, A/C heater assembly
Flasher
11= 7.5A Instrument cluster, Main light switch, RABS resistor
12= 10A Power window relay, Washer pump relay
13= 20A Stop lamp switch, Brake pressure switch
14= 20A Rear Anti Lock Brake system (RABS) module
**10A 4WABS module**
15=7.5A Instrument cluster
16= 30A Windshield wiper Motor, Wiper Hi-lo relay, wiper run/park relay
17=7.5A Cig lighter
18=15A Drivers unlock relay-All unlock relay
19=25A PCM power diode
20=7.5A RAP module GEM module, Radio
21=15A Flasher (hazard)
22=20A Aux power socket
23=15A Turn signals
24===not used
25= 7.5A GEM module, Instrument cluster
26= 10A Battery saver relay, Electronic Shift relay, Interior lamp relay
Power window relay,Electronic shift control module, transmission control
27=15A Switch,DRL, Backup lamp switch, DTR sensor,Instrument illumination dimming control module
Dome/map lamp, GEM,electronic shift,Interior lights,Glove box lamp and switch
28=7.5A GEM module-Radio
29= 15A Radio
30=15A Park lamps, trailer Tow relay
31===not used
32=10A rear blower
33=15A Headlamps, DRL module, Instrument cluster
34=7.5A Rear integrated control panel, CD
35=10A RABS test connector
36=7.5A CD, rear integrated control panel, memory seat, Message center
__________________
SOURCE: need to see fuse box diagram for a 2004 ford explorer
For the '04 Ford Explorer, here you can find the Owners Manual, and check the page 186 and next for the Maxifuses, Minifuses and Fuses.
I really hope helped woth this (remember rated this help). Good luck.
