SOURCE: Xerox Docucolor 12 copier doesn't print when sending to FieryEX12
There is no 1 part that deals with this issue i'm afraid. The copy from the glass uses all the boards in the same path that a print uses. It definately rules out the machine fault. I would guess that the machine isn't set up properly to receive these fierys. Just make sure all connections are secure, if not try other cables.
SOURCE: Xerox Docucolor 12 not recognizing network controller
check ur fiery card that connect to copier
remove card clean any dust at the pins / slot lines then try
SOURCE: Can you scan to file on the xerox docucolor 12
yes it needs one printer cable and one scanner cable connected between fiery and machine
and scangear software install and remote compputer
