The exclamation mark means you don't have the proper driver installed and the device may or may not work properly. If you don't have the driver CD's you will have to find the driver by searching the internet for it, download it, and install it. The hardest part can be finding the proper make and model of the device. If you know that already, it should be easy. For example if your VGA card is a ATI VGA Wonder, search for that. If you don't know, there is a means of finding it. In the same device manager where you saw the exclamation marks, click on Properties for the device, then click on the Details tab. You will see something like PCI\VEN_10DE&DEV_01DF&SUBSYS.......... Use this string (yours, not my example) in your internet search and you will probably find the vendor, make and model, then you can search for a driver. Once you have the proper driver downloaded, go back into the Device Manager and click on the Driver tab of the device's properties. There is a button labeled Update Driver that starts a wizard, which will let you choose the driver you downloaded.
