Nintendo Wii Console Logo
Posted on Apr 12, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My wii will not work the wires are plugged in but the light is not on it was working fine yesterday but it wont work now please help
Anonymous
Level 2:
Scholar:
  • Expert 131 Answers
  • Posted on Apr 12, 2011
Anonymous
Expert
Level 2:
Scholar:
Answers
131
Questions
0
Helped
41008
Points
289
Try your wii power supply in your friends' house. If your power supply didn't work on your friends wii, Buy new power supply. If it worked on your friend's wii then your wii is dead. Call Nintendo to take care of it. If you dont have a warranty, do it yourself. Take out the motherboard and google Wii FUSE. Chage the fuse. If you don't have the fuse, use soldering iron and join the palce you place the fuse together. If that didn't work again, Replace the wii motherboard. Trust me your wii will work this time and your MII you created will still be there because they are all on your harddrive not wii motherboard.
Rate if this helped you.
Our wii is about 6 years old. It was working fine yesterday, today it doesnt even act likes it's getting power. No lights come on. Reset doesn't work, switched outlets...nothing happening.
Wii console's are known to over-heat. Try letting it cool down for a day with no power cables plugged in. Try and turn it on the next day, and if it doesn't work, my best guess is that it over-heated to the point of giving up. And when you plug it back in, blow in all the ports and cables just to be safe. If none of this works, it is either broken or needs more expertise than I can give.
My relisys monitor wont come on. it was working perfectly yesterday and now wont work at all. the screen is just black and no lights are coming on. everything is plugged in and switched on.
You might have a break in the cable or a loose plug, try wiggling some of the wires around and check to make sure that all the plugs are in as far as they can go.
My Wii will not turn on and there is no red light. All the cords are plugged in and it was working fine yesterday but when I woke up it just stopped working.
This shows that the the circuit inside is fried because of sudden high voltage you'll have to take it to the nearest nintendo store and get it fixed. To prevent this from happening again turn your wii off and then switch its power source or pull the plug after you finish playing.
1helpful
Wii console not working correctly
When you connect to the internet wirelessly and Wii Connect24 your Wii will stay connected and recieve messages, updates, etc. That is why the disk area stays blue and the amber light stays on. Sometimes this will create a power failure. Just unplug your Wii from the wall and let it rest for a few minutes and plug it back in. The problem should be solved.
2helpful
Wii worked fine yesterday. Will not power up
This is a common problem with the Wii. Considering how often I see this problem, I'm amazed Nintendo didn't address it in their FAQ on the Wii. It happens almost every time there is a power surge or the power goes out, etc.
Even if it's hooked up to a surge protector, this happens. Power comes back on, but the Wii appears dead. It won't turn on, and the LED indicators won't light. If there was a power surge, or the power went out,etc...anything, this will happen. The problem is with the AC adapter,not the Wii itself.
You need to reset the AC adapter to get the Wii to work again. There is a circuit inside the AC adapter that needs to be reset. Unplug the AC adapter from the wall/surge protector outlet. Don't unlpug it from the Wii, it has to be at the outlet. You have to kill power to the adapter.
Unlpug it from the wall/surge protector outlet, and leave it unplugged for 5 or 10minutes. This will kill power to the AC adapter, and give the circuit time to reset. When you plug the adapter back into the outlet after 10 minutes, the red led on the front should be lit up.
2answers
3helpful
2answers
Blank screen when wii is on
Fiend your solution direct from nintendo. Here is your solution....
http://www.nintendo.com/wiiconsole/prob676ijt65/solution
aqrtyctr-108
No power to guitar!
check the plug in wires to make sure they are not broke
blow into wii remote back port and guitar connecter
Wii drum symbol in world tour just quit
WIRES ARE VERY THIN.YOU WILL HAVE TO TAKE SET APART AND LOOK FOR THE WIRE THAT HAS COME APART . YOU CAN FIX THIS BY SOLDERING WIRE ,OR TAKE SET BACK TO PLACE OF PURCHACE. REMEMBER YOU WILL EVENTUALLY RUN INTO THIS SAME PROBLEM, WHICH YOU CAN FIX ON YOUR OWN.
3answers
Wont turn on
Have you checked all the cables to ensure they are properly attatched?
Top Nintendo Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Aron
Sean Wright
Sean Wright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
