CHECK YOUR OIL DIP STICK MAKE SURE YOU HAVE ENOUGH OIL IN THE CRANKCASE.YOUR ENGINE CALL FOR 7 QUARTS OF OIL. IF YOU HAVE THE INLINE 6 CYLINDER.CHECK OIL LEVEL ON DIP STICK.YOU SHOULD BE AT FULL MARK.AND NOT ON THE LOW MARK.IF SO YOU NEED ADD LITTLE MORE OIL TO GET TO THE FULL MARK.YOU CAN USE 10W 30 FOR SPRING AND SUMMER WEATHER. 5W 30 FOR COLD WEATHER COLD CLIMATE.I RUN 10W 30 YEAR ROUND IN ALL MY NEW CHEVY AND OLDSMOBILE VECHICLE HAD NO PROBLEMS.IF OIL LEVEL CORRECT YOU COULD HAVE FUEL PROBLEMS.COULD HAVE STOPPED UP FUEL FILTER, BAD GAS,
