Question about General Electric WCVH6800J Front Load Washer
My general electirc washer model wcvh6800j1ms, after working some minutes and after drain all the water in the tub, fills the tub with more water totally unusual (almost full all the tub, this washer use normally a few liters of water, not this ammount), and after this, drained all the water without any work or process, when de washer is totally drained, the washer changes the cicle and puts the washer in pause mode. any idea?
    Scholar:
  • 44 Answers
I had a similar problem ... mine was related to a hole in the pressure switch hose (code E22). Inside the washer, there is a pressure switch that senses how full the tub is. It does so using air pressure at the bottom of the tub -- air hose gets "pushed on" by the filling water and causes a pressure spike the switch. If you develop a leak in the air hose, the pressure switch never gets exhausted. There is a safety feature that engages if the water runs for more that 8 minutes without the pressure switch engaging. E22 is one of the codes related to this event. Easy way to see if this is an issue is to run a diagnostic test.
Check out this posting for how to do so: http://www.fixya.com/support/t9576766-found_small_part
Test T02 will show you the most recently encountered codes. At the bottom of that posting is a link to the code definitions with problem resolutions: http://www.fixya.com/support/t9556917-ge_model_wcvh6800j_error_code_04
If you do find a pressure switch related code, here's how to fix it: http://www.fixya.com/support/t9807344-ge_front_load_washer_stops_45_min_35_min
Posted on Jul 28, 2011
6ya staff
SOURCE:
Kenmore washer frontloader model 417.41122410 code E11
An E11 error indicates a problem with the incoming water. The error will occur if the tub doesn't fill normally in about 8 minutes. This could be related to closed shut-off valves, failing anti-flood hoses, or debris in filters in the hoses or at the inlet valve on the washer. It could also come from a fault with the sensor that detects the weight of the washer tub, a problem with the reed switch that tracks water flow into the washer, the air tube that goes to the reed switch or a failure of the inlet valve. It can even indicate that the end of the drain hose is below the water level in the washer and is siphoning water out as the tub fills.
If no water or a trickle of water is reaching the tub, first make sure that the shut-off valves are open. Next close the valves and disconnect the hoses. Place the hoses into a bucket and check the water flow by opening the shut-off valves. Shut off the valves. Clean the filters, including those in the inlet of the washer. Reconnect the hoses or replace them with new ones if there was low flow. (Check the flow at the shut-off valves themselves with a similar bucket under the valve opening, if you can.) If these steps don't work, you need to replace the inlet valve assembly. It failed in the closed position.
If water is filling the tub normally and flowing out the drain, check the drain hose position. If the tub is filling and is held in the tub, then the washer isn't correctly measuring the water flow. Check the reed switch and that tubing by blowing into the tube. Replace a faulty switch and remove any blockages from the tubing. Check the wiring harness to ensure that the message got to the control board.
See http://www.searspartsdirect.com/model-number/41741122310/0582/0153200.html for parts diagrams and price lists. You need the control panel diagram.
I hope this helps.
Aug 15, 2017 | Kenmore Washing Machines
Unit acts like it has received water then continues to cycle as if it hasn't, no water is pumped???
Symptom Check
Click on underlined items for further information Washer does not work and makes no noise Washer does not work but it does make noise No water is entering the wash tub
- or no hot water
- or no cold water The water fills the wash tub too slowly The tub does not fill with enough water
  • Test the water level switch
  • Check that the drain hose is positioned roughly as high as the top of the inner tub
The water overflows the wash tub Water drains out during the wash or rinse cycle
  • Check the drain control lever
  • Test the drain control coils
  • Check the cam bar
  • Test the timer control
Wrong temperature of water is used
  • Water supply hoses may be reversed
  • Hot or cold water supply valve may be turned off
  • Water supply hose may be kinked
  • Check water inlet valve
Water drains out while it is filling
  • Check the drain hose, it should be at least as high as the top of the wash tub, about 38 inches.
  • The drain hose must sit loosely in the house drain. Do not seal the air gap around the drain hose or a siphon will occur.
  • Check the cam bar
Water drips into the wash tub when the washer is off Water does not drain out of the wash tub Water is leaking onto the ground
  • Inspect the water supply connections
  • Inspect the drain hose
  • Inspect the water pump
  • Inspect outer tub for cracks or corrosion
  • Inspect the tub seal
  • Inspect the tub bearing
Agitator does not move Agitator movement is weak or moves in only one direction
  • Inspect the agitator
  • Inspect the motor coupler
  • Inspect the drive belt (belt drive only)
  • Inspect under the washer for soot (clutch)
  • Test the motor
  • Inspect the pulley
  • Test the transmission
  • Inspect the pump coupling
Drum does not spin
  • Test the lid switch
  • Test the centrifugal switch
  • Test the motor
Clothes are too wet after spin cycle This may be a spin problem or a drain problem
Drain:
  • Make sure the drain line is clear
  • Check the drain hose for a partial blockage
Spin:
  • Test the motor
Cycle does not advance
  • If the washing machine fills with water and begins agitating, but the timer does not advance, the timer probably needs to be replaced
  • If the timer does not advance while the washer is in a spin cycle, the timer probably needs to be replaced
  • If the timer does not advance during the rinse cycle, check whether water has filled the tub, if not, it is likely cold water related. Check the cold water supply valve, check the supply hose for kinks, check the filter screen and check the water inlet valve
Burning or electrical smell
  • Unplug the washer
  • Locate the source of the odor then read the instructions in the related section
Foul or stale odor coming from washer or clothes
  • Check that the drain line is clear
  • Check the drain hose for kinks or blockages
  • Check pump for blockages
  • Check for build up of soap in the outer tub
  • Check for article of clothing stuck in the outer tub
Noisy or vibrates too much
  • General tips
  • Balance the load
  • Level the machine
  • Inspect the water pump for a blockage
  • Inspect the coupling
  • Inspect the transmission
  • Adjust the drive belt tension
  • Check the motor bearings
  • Check the drum brakes
Goes out of balance too often Clothing is damaged
  • Inspect agitator for cracks or rough spots
  • Inspect for rust spots
Jul 11, 2015 | Washing Machines
Leak in front
see this steps and fix it. God bless you
Drain Pump
If the washer is leaking water the drain pump might have a hole or crack. Or, the bearings might be worn out. Replace the drain pump if it is leaking water, they're not repairable.
Enter your model number to see parts for your washing machine.
Help me find my model number
Tub Seal and Bearing Kit
If the washer is leaking water the tub seal and bearing might have a tear or rip and is letting water leak past. The tub seal and bearing can be replaced. This is common and relatively easy to replace.
Tub Seal Kit
If the washer is leaking water the tub seal might have a tear or rip and is letting water leak past. The tub seal can be replaced. The tub bearing often gets damaged when the seal leaks. consider replacing the tub bearing along with the tub seal.
Tub Spin Seal
If the washer is leaking water the tub spin seal might have a tear or rip and is letting water leak past. The tub spin seal can be replaced. This is common and relatively easy to replace.
Tub Seal
If the washer is leaking water the tub seal might have a tear or rip and is letting water leak past. The tub seal can be replaced. When the tub seal fails water gets into the tub bearings and usually causes the bearings to go bad also. It is a good idea to replace the tub bearings with the new tub seal.
Door Boot Seal
If the washer is leaking water the front door boot seal might have a tear or rip and is letting water leak past. The boot seal can be replaced. This part can tear when the washer is overloaded. This is common repair.
Tub to Pump Hose
If the washer is leaking water the hose from the tub to the pump might be split or torn. Don't try to cut off the bad piece of hose and stretch it to fit the pump, this will put strain on the remainder of the hose and may cause a sudden and complete failure of the hose which will dump potentially hundreds or thousands of gallons of water onto the floor because the next time the washer tries to fill all of the water will end up on the floor and so the washer will never shut off the valve. Any time there is a damaged hose, replace it completely with the OEM part.
Washing Machine Fill Hose
If the washer is leaking water, check the fill hoses on the back of the washer, this is the most common place for water to leak. If the washer still has the original black rubber fill hoses replace them with stainless steel or some other, more durable hose.
Drain Hose
If the washer is leaking water check the drain hose. The most common places for the hose to spring a leak is from the connection to the pump out to the back of the washer. Another common occurrence is when the washer gets pushed too far back against the wall.
Jul 09, 2013 | Bosch Nexxt Platinum WFMC640SUC
Water runs but doesn't fill tub and wont spin if put on spin cycl
The water-level switch regulates your washer's fill volume. This switch is usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. If the switch is defective, it may prematurely signal the water to shut off. If so, you probably need to replace the water-level switch.
Jan 09, 2010 | GE WBSE2090A Top Load Washer
417.43142300 Kenmore drains while trying to fill with water
try this the drain hose from the washer is stuck to far down the drain .allow only 8 to 10 inches down drain if the house drain is lower than top of tub it will do the same thing. raise the drain haundi24
Oct 27, 2009 | Kenmore 43142 Front Load Washer
Whirlpool washer - tub drains while it fills.
Your drain is to low. Make sure that the drain that your discharge hose is going into is at least as high as the washer. If not the water will drain out as fast as you can fill it.
Aug 15, 2009 | Whirlpool Washing Machines
When tub filling, it drains out at the same time.
The outlet of the drain hose must be higher than the water level inside the tub--normally the pump inside removes the water when needed. Get a plumber to install a proper height drain pipe for you.
Jul 16, 2009 | Haier XQBM22-C Top Load Washer
Frigidaire Front Load washer Model FWT645RHS1 wont fill with Water
The drain hose might be too low. Make sure the drain hose is at least three feet above the floor.
May 31, 2009 | Frigidaire Washing Machines
Water comming from under washer front side
 Check the following:
Are the fill hoses tight?
Are the fill hose washers properly seated?
Is the drain hose clamp properly installed?
 Is the sink or drain clogged? Sink and standpipe must be able to handle 17 gal. (64 L) of water per minute.
 Is water deflecting off the tub ring or the load? Center the tub before starting the washer. The wash load should be balanced and not overloaded. The fill or spray rinses can deflect off the load. The washer must be level. The front feet should be properly installed and the nuts tightened. Reset the
rear leveling legs (if needed).
Mar 22, 2009 | Whirlpool LSR5132PQ Top Load Washer
Water keeps going and going and going!
the water is draining back to the ocean. The drain hose was not emptied properly from its last use. Put the machine in spin cycle (about 5 minutes) only to spin out the water from the outer tub completely and retry washer. If still problem, then visual check drain hose that it still has a "rising" section higher in altitude than the water level of inner tub (when working properly) before it makes a U-turn downward to send back to the ocean. You can also test the drain hose by putting machine in fill mode and crimping off the hose (fold hose over) to simulate a good drain hose. At this test, you should not "feel" water running through the hose if successfully crimped.
Jun 21, 2007 | Estate TAWS800JQ Top Load Washer
General Electric WCVH6800J Front Load Washer Logo
2,397 people viewed this question
Top General Washing Machines Experts
Kevin
Kevin
geapptech
Dw Wooten
Dw Wooten
Are you a General Washing Machine Expert? Answer questions, earn points and help others
