Question about D-Link AirPlus Xtreme G DI-624 Wireless Router (DI624RE)
WIFI just stopped working. No problem with modem and all lamps looks like normal on the router (!) . I can however not see any wifi connection when looking at my network connection. Just suddenly stopped working :( I have rebooted the router (and my laptop), no changes. ALl lamps are still working properly, but i am not able to use WIFI
    Top Expert:
  • D-Link Master
  • 8,537 Answers
This is all i could find out..
The way to fix this is to unplug both your modem and your router (you may have one piece of equipment that acts as both) and wait a full 60 seconds. Then plug them both in again and wait for all the lights to stop flashing. At that point, try to reconnect to the Internet again.22 Mar 2017
What To Do If Your Wi-Fi Suddenly Stops Working ' Tech for Luddites
https://techforluddites.com/fix-wi-fi-problems/..
or go to this link.
WIFI just stopped working Google Search
Posted on Oct 30, 2017
SOURCE:
  • 624 Answers
SOURCE: Sympatico & DLink DI-704P
It usually is simple, and hopefully the answer is as well. If you haven?t already done so unplug the modem and the router. Wait for a few seconds and then plug the modem in followed by the router. Reboot your PC and try the Internet again. If it still doesn?t work then I would try doing a hard reset of your router and reconfigure using the setup process outlined by the manufacturer. If that still doesn?t work let us know and we?ll continue ?.
Posted on Jan 01, 2007
SOURCE: Configuring DLink Wifi router for Reliance broadband
Reliance Wimax will be Dynamic (DHCP)
Step 1 :
Connect the Wimax wire from the wall outlet (power adapter provided by Reliance) to the computer directly. The computer must be in DHCP mode.
Check the IP Address of the Computer. It should be a public IP Address.
Step 2 :
Open a web browser. If you try to open any page, it will take you directly to the Reliance Broadnet Login page. Login with your Reliance User ID and Password. Then Log out.
Close the web browser.
Step 3 :
Now, connect the wimax wire to the WAN Port on the Router and the computer to any LAN port. You can open the Router Setup Page. Do MAC Cloning. Then, save changes. Run DHCP on the Router.
Also you can configure wireless network, by changing the SSID and security.
Step 4 :
On the wired computer, open web browser, go to Reliance Broadnet login page and login and start enjoying the service.
One problem, you might face is when the Router is turned off in between. You may have to repeat the Steps 1,2 & 3 to get the connection back.
Posted on Oct 20, 2008
marked
  • 6487 Answers
SOURCE: how to change (or update) wap to wpa encryption on ASUS WIFI-B Network Adapter
With this Asus wireless B adapter even the new driver dont support WPA wireless security , because right now sicne WPA is a much newer and higher type of wireless encryption only some wireless B adapter supports that and sorry to say this wireless adapter that you have don't support it even with the latest driver so it will be better to get a new wireless G adapter that supports WPA 100% , you can get the wireless adapter from Asus or from other wireless device manufacturer like Linksys, Netgear. Dlink and Belkin....
Posted on Nov 02, 2008
  • 340 Answers
SOURCE: di-524 dlink; wireless laptop connects but no internet or network
Your wireless card is dead, replace.
Posted on Nov 23, 2008
SOURCE: My 2wire router will not connect to my nintendo ds wifi system.
The DSi only works with WEP encryption. The 2Wire and most other newer routers use WPA encryption.
Simply logon to your router with a web browser. The default IP for it is 10.1.1.138 but it might be different, just check the manual or internet for the IP. Go to "Home Network" then "Advanced Settings" and change the security from WPA to WEP and save.
Thats it!
Hope that helps.
Posted on Apr 11, 2009
Does wifi require a router? What is the difference between a router and a cable modem? I have activated a network connection, but I don't know how to activate wifi to use my browsers.
Modem- connects to incoming cable or phone line, it creates a connection between the internet your computer or other internet using items.
Router- splits up the connection to the internet to share it with multiple computers, TV's, cell phones, ect. Can be wired or wireless (wifi)
Wifi- wireless connection, it's always a router too because multiple devices work with it.
Now here's the confusing part, you can get any combination in one modem.
Cable modem, no router, no wifi, just hooks up to one wired device.
Cable modem, with router, no wifi, usually can hook up to 4 wired devices.
Cable modem, with router, with wifi, can have 1 to 4 wired devices and has wifi which can connect to hundreds of devices.
You can also get Cable modems with phone connections they use the internet service to connect to the phone system.
To activate the wifi, you usually need one computer to change the settings to set a name and password for your wifi. Then all your other devices will have to be connected to that named signal and use that password to set them up.
Nov 12, 2016 | Computers & Internet
Tip
Multiple Computers on Same Network, Continual Internet Connection Dropout
After adding that second or third computer to your home network are you constantly fighting over who's using the internet connection? When your high schooler logs into his facebook chat, are you getting dropped off of your internet connection?
Or have you added a wifi router and is your whole network not staying connected like it did before you added your wifi?
These are common issues and we answer these questions often at FixYa.
Here is s a tip that will get you past the internet connection being dropped by someone else on your network attempting to log into the internet or help you get that wifi up and working with out all the cut outs and drop offs.
Follow this simple procedure and you'll be amazed!
1. Turn off everything. Turn off computers, routers, modem, printers... everything that's on your LAN (local area network) or home ethernet.
2. Turn on your wireless router next. With the ethernet cable connected to your wifi router to your modem and let it cycle up to running. If you aren't running wifi, do this with your main router. Make sure your modem and everything else is still off.
3. Turn on your modem (enet cable attached to wifi router or main router) and let the modem cycle up to running.
What you've done is allowed your wifi router to be established as the "MAC" Address for your modem. Modems look for a single MAC address. Once the router has this address, the router will maintain the connection with the modem and the internet, AND will assign MAC addresses to your computers, network printers, network routers etc, while still maintaining your connection to the internet.
4. Turn on all other peripherals, computers and network printers. At this point the order of power up isn't important, because your router will be assigning separate addresses to all the computers, etc on your network.
That's it! The secret's out! Just keep this handy... remember if you have power outage, you'll need to reboot in this order again... Happy Home Networking
on Dec 02, 2009 | Computers & Internet
Netgear wifi router
1) does it lock up completely or will it work hard lined when wifi fails?
2) do all devices wireless fail or just a single device?
3) do you lose connection to the wireless completely or keep the connection but lose access to the internet? (confusing but very different to me)
in the end you could narrow down the problem but if you have already reset to factory defaults and set back up again and again then it may be time to retire that old router.
Dec 28, 2012 | NetGear DG834G Router
I cant get wifi and internet on my computer at the same time
Hi. Let's hava look at what you are doing.
I'm guessing that you have a cable modem a dlink router with wifi and a computer, right?
If you connect the cable modem to the computer you have internet. You shouild also have wfi but the wifi will not give you internet because it is disconnected from the modem.
The Dlink has to be connected to the modem but it will also need to be configured. To *** that you will need help from your cable company.
The connections should be. Modem connected to the outside world. Dlink connected to the Modem. Computer connected to the Dlink by either wifi or Ethernet.
Feb 28, 2012 | D-Link RangeBooster G WBR-2310 Wireless...
My wireless has suddenly lost connection. My wired works perfectly.
If the wireless has stopped working, but wired can, either your wifi modem on your laptop needs to be reset or the wifi router has to be reset. Make sure you have restarted your laptop and unplugged the wifi router.
Feb 26, 2011 | Linksys Wireless-G WRT54G Router
How to connect wifi network in archos 28 internet tablet
This is normal. To save energy, the ARCHOS always starts up with the WiFi set to off. You must manually use the Fn-F3 keys if you want to activate the WiFi connection.
I cannot connect to the Internet over WiFi, what's wrong? Make sure that your WiFi is activated. This can be turned on and off with the blue function key pressed down and then the F3 key. The blue WiFi indicator just below the touch-pad will light indicating that it has been turned on.
My WiFi router/modem is on and working, but it does not show up in the list of wireless networks. What's wrong? It could be that the WiFi modem/router is hiding its SSID. This is done for security purposes sometimes. You can either change this on the WiFi modem/router (see its instructions) so that it broadcasts its SSID (and then you'll see it in the list on your ARCHOS 10) or you can go into the advanced settings of the Wireless Network Connection screen to the Wireless Networks tab and 'add' a new connection. You will need to know the SSID name and its other connection parameters.
Dec 17, 2010 | Archos 28 Internet Tablet
Im trying to connect my ps3 to my wireless router. it has recently stopped working. is there anything i can do?
Sure! Try this:
1 Turn your network off. Modem router, computer, printers etc. turn them off.
2. Leaving the wireless router connected to the modem with an ethernet cable (modem power off) , turn your wifi router on and let it cycle up.
3. After the router is cycled up, turn power on to your modem , leaving the ethernet cable connected to the wifi router's internet port. Let the modem cycle up .
4. After this, turn on all computers, routers and etc... no particular order.
This should allow your modem to find the wifi router and direct it to your computer via wifi or ethernet..
Dec 08, 2009 | Computers & Internet
Won't stay connected to internet
Do any of the computers connected (wired or wireless) to the router use any file-sharing software (LimeWire, Bit Torrent) ?
If so, stop using those programs, and then see if the problem does not happen.
If the problem still exists, it's time to replace the router.
May 27, 2009 | Belkin (F5D7230-4) Router (587009)
No wifi connection
Verify which MAC Address U have Cloned. MAC Address of Your PC WiFi and Cloned One must not be same otherwise it will not work...
Feb 02, 2008 | Belkin (F5D7231-4) Wireless Router
D-Link AirPlus Xtreme G DI-624 Wireless Router (DI624RE) Logo
66 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Ekse
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
