Yes, you can turn off the power saver feature on your display. The steps to do so may vary depending on the brand and model of your display. Here are some general steps to disable power saver on a monitor:
- Right-click on the desktop and select "Display settings".
- In the Display settings, click on "Advanced display settings".
- Click on the "Monitor" tab and look for a "Turn off display after" or "Power saver" setting.
- Change the setting to "Never" or disable it completely.
If you are using a KVM switch, it may also have a power-saving feature that is causing the display to power off. You may need to check the manual or the manufacturer's website for information on how to disable the power-saving feature on the KVM switch.
If you are using the Microsoft Win 10 "project" feature, you can adjust the display settings by following these steps:
- In the Display settings, click on "Project to this PC".
- Look for a "Turn off display after" or "Power saver" setting and change it to "Never" or disable it completely.
These steps should help you disable the power saver feature on your display and prevent it from turning off. If you are still having trouble, please provide more details about the brand and model of your display and KVM switch, and I'll do my best to help you further.
