Sewing Machines Logo
Posted on Apr 12, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I am wanting to set my machine (quilters dream 6603) for the best basting stitch I can. I am having trouble figuring out how to set the machine. Thanks.
Tally Girl
Level 3:
  • Elna Master 1,134 Answers
  • Posted on Apr 13, 2011
Tally Girl
Elna Master
Level 3:
Answers
1134
Questions
0
Helped
398511
Points
2496
I haven't been able to find a 6003 manual or a good image of the stitch range for this machine on line. However, a basting stitch might look like " . _____ . _____. " on your stitch selector. As your machine is targeted for quilters I'd have expected it to have a basting stitch in its range.
If there is nothing like that, then just dial up the longest possible straight stitch, ie take length up to 4 or 5, whatever the maximum number is. Then loosen off the top and bottom tensions and stitch away.
If you are using this to baste a quilt top, botton and batting together, I've discovered a product called "spray basting" which is fantastic and "glues" the layers together while you sew them. You need a big clear floorspace though and put paper down under the project. But it works great.
Trust this is of help to you.
1helpful
I have a Brother XL 3500 what do I set the dials on for a basting stitch
What is the stitch length for a basting stitch?
Basting a Seam for Fitting:
At the sewing machine, set the stitch length to 5mm. This will make it easy to remove any unwanted stitches. Sew the seam at the desired seam allowance. After fitting and the adjustments have been made, sew the seam with a normal stitch length of 2.4mm.
Sewing Basics - Basting - Janome
and also related to Brother
https://www.google.com/search?q=Brother+XL+3500+Basting+Stitches
Is the Kenmore sewing machine 15343 able to do a baste stitch? If so, how?
A baste stitch is basically setting the machine to a straight stitch with the longest stitch length available. Loosen the top tension slightly if you want to remove the basting later.
1helpful
How do you machine baste on a brother PE 830DL I am wanting to embroider on stretch material and I was told to float the stretch material and baste it to the tear away in the hoop thanks
A basting stitch is just a matter of setting the stitch length to very long. If you want to remove the basting stitch after your project is complete, you can also loosen the top tension so the bobbin thread will pull out very easily.
Wondering if a wash-away fabric spray adhesive will work just as well.
I want to baste and dont know how to set straight stitch and length.
To baste, set the stitch length as high as possible (zero is a non-stitch length, probably 4 or 5 on your machine is the largest stitch length). Set the stitch width to zero so there is no zig-zag.
1helpful
2answers
How do I set the machine to do a basting stich
if the machine can do a basting stitch the information should be in the sewing machine manual, if you don't have a manual, add a comment with the name and model number of the machine and someone should be able to help you find one.
or you can also try youtube for a video
My elna quilters dream machine has 84o test mode on display and I can't select other stitches
you might think about having the machine check to see if there is something wrong with the motherboard
How do I set for basting
Some compuerised machines will have a basting stitch programmed in, it may have a symbol like a dot then a long dash then another dot. This will give you a decent spaced basting stitch. On mechanical machines sometimes you can get a basting needle plate - you set up for the longest widest zigzag stitch and the tube on the plate makes one side of the zig not catch so you get a long straight stitch.
But if you are joining silky fine fabrics together, then needle and length of thread doubled is still the best way, takes a little longer but the fabrics won't creep and slip.
I have the Elna 6003 quilter's dream machine. The problem is that it is stuck in the "bobbin winding" mode and will not allow me to change stitches. I have tried turning it off and turning it...
Does this have a bobbin winder post and stop at the top right. If so, is the bobbin winding post moved back to normal position or up against the post?
Being computerised, if you have tried powering it down and all the settings are correct, then it might want a trip in the car to see the technician to sort out this fault.
Elna Quilter's Dream 6003 the machine is fine with
Hm, wondering if it could be the presser foot pressure setting. Most machines have this capability where the amount of pressure applied to the feed dogs can be increased or decreased. You might check your owner's manual,.
Top Elna Sewing Machines Experts
Mike Cairns
Mike Cairns
SmartAviator
SmartAviator
Ngoro
Are you an Elna Sewing Machine Expert? Answer questions, earn points and help others
