I don't have this exact program, but having used similar ones, here is my two cents worth:
In the app's header menu, look at each of the drop-down menus to find an option named Settings or similar.
In settings, there should be a user setting for default path for Saved files.
Quite often, the program's default is one of these 'examples':
C:\Program Files (x86)\CreateaCard\Saves\
C:\%homepath%\Documents\Createacard\
C:\%homepath%\appdata\
If you find this, you can simply edit the path to your preference then exit and reboot PC.
BAGCACP8 should then remember your settings.
Hope this helps you.
Clive.
