Hello
Your Samsung HT-C350 is paretial locked. You have to unlock it. If you have forgotten the passcode, do these.
There is no no dic inside I thinks. If there is a disc inside, remove it by by anyway opening the device. If there is a disc inside, the player will show its contents and you can confirm it.
Press and hold STOP button on the remote control for 5 seconds or more. All the settigns will revert to Factory Settings.
OK.
Actually, while I was trying to find a way to avoid opening the device by any means, I found that you can unlock the try by holding the "eject" button on the dvd's front panel. You can, of course, also block it the same way.
It doesn't matter if there's a disc inside the device or not.
