HP LaserJet 2840 All-In-One Printer Logo
Posted on Apr 12, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have an HP 2840 and I have constantly been getting a scanner error 52 code. Per the text and research they say power it on and off, which did not work. Other experts say to replace the scanner assembly, which I did go and buy one, but I cannot find online anyplace that shows you how to fix them.
Patrascu nicolae
Level 2:
New Friend:
  • Expert 85 Answers
  • Posted on Apr 12, 2011
Patrascu  nicolae
Expert
Level 2:
New Friend:
Answers
85
Questions
0
Helped
20820
Points
246
Hp 2840 error The device HAS Experienced 52 year internal hardware error. theoretically not initialize the scanner, to be replaced after that piece or set of diagnostic scan (logic board or motor, etc.
Hp 2840
This printer has the rotating carousel assembly and therefore it is susceptible to becoming misaligned very easy and this could be the source of your scanner errors. More than likely of an inserting the wrong cartridge into the carousel...it can be fixed but judging by the age of this printer and the amount of labor to repair I would just junk this because of the time and labor involved ..plus there are definitely more productive and efficient models for a very low cost that will do you some justice.. that's just my opinion.
If you need further help, reach me via phone at https://www.6ya.com/expert/howard_563901c2e8628759
Scanner error 5 on HP Color Laserjet 2840
Scanner Error 52 is a hardware error. If turning the power off , waiting 30 seconds and turning it back on does not solve the issue the the scanner assembly might need to be replaced. Another thing to try is make sure the printer is plugged into the wall not into a surge protector. Aside from that you may need to have the scanner assembly replaced.
Scanner error 5
Based on the service manual the Error: Scanner Error 5 doesn't exist. However 52 Scanner Error exists. If the scanner doesn't function anymore the recommended solution is to replace the scanner assembly.
Hp color laserjet 2840 error 52.
I noticed that this was posted in Oct 2010. If you are still waiting for an answer,
the printer has a scanner error. Power off for about 30 seconds. Power on, if
error persists, the scanner assembly will have to be replaced.
I hope that you got it fixed by now!
Scanner error 5 turn off and on
Recommended action
  1. Verify that the connection cable is not loose or damaged. Replace the cable if necessary, and try the scan again.
  2. If the error continues to persist, contact Hewlett-Packard for technical support to troubleshoot the problem. 52 Scanner Error DescriptionThe device has experienced an internal hardware error. Recommended Action
    1. Turn off the power by using the power switch, wait at least 30 seconds, and then turn on the power and wait for the device to initialize.
    2. there is no much to do, is a hardware error, you must contact hp to your scan unit be replaced
2helpful
2answers
52 scanner error on HP Color Laserjet 2840
  2. If the error is still unresolved, contact Hewlett-Packard for technical support to troubleshoot the problem. Call HP for telephone support
1helpful
4answers
Hp2300 laser printer
52.x PRINTER ERROR alternates with To continue turn off then on Possible printer control panel error messages 52.0 PRINTER ERROR 52.1 PRINTER ERROR 52.2 PRINTER ERROR Description A temporary printing error occurred. The x can equal one of the following: 0 = Scanner error 1 = Scanner startup error 2 = Scanner rotation error This error can also indicate a problem with the shutter tab on the print cartridge. Action
  1. Turn the printer power off, and then turn on the printer power.
  2. If the message persists, check the print cartridge for damage.
    1. Verify if the shutter tab on the cartridge is broken or damaged. click on the below link. Shutter tab on the print cartridge
  3. 1 - Shutter Tab
  4. Replace the cartridge if damaged.
If the message continues to persist, then download the printer software based on operating system and reinstall.
HP Laser-Jet 2300d Printer Software
Regards
Chittaranjan
4helpful
5answers
52 scanner error
HP LASER PRINTER ERROR CODE 52 – INCORRECT SCANNER SPEED ERROR
HP LASER PRINTERS 2, 2D, 3, 3D
1. Defective cable laser scanner to dc controller.
2. Defective laser scanner assembly.
HP LASER PRINTERS 2P, 2P+, 3P
1. Bad scanner motor.
2. bad dc controller.
HP LASER PRINTERS 3SI, 4SI, 4V
1. Faulty cable assembly.
2. Scanner motor problem.
3. Defective laser scanner assembly.
4. Defective dc controller.
HP LASER PRINTERS 4, 4+, 5
1. Faulty laser scanner cable.
HP LASER PRINTERS 4L, 4P, 5P, 5L, 5SI
1. Temporary error. Scanner startup failure.
2. Improperly fitted scanning assembly.
3. Scanner cable problem.
4. Defective laser scanner assembly.
5. Defective dc controller board.
HP LASER PRINTERS 1200, 2200, 3100 FAX, 3200 FAX, 4100
1. Temporary error. scanner rotation error.
2. Replace contact image sensor.
4. Replace laser scanner.
5. Replace cables to laser scanner and engine board
HP LASER PRINTERS  1100, 2100, 4000, 4050, 8000
1. Scanner start up error
2. Replace scanner cable to the D.C. controller and back to scanner. Or replace scanner cable from engine board to scanner ***'y.
3. Replace scanner ***'y.
4. Replace the engine board.
5. Replace the D.C. controller only on the 8000.
HP LASER PRINTER 2300 ERROR 52.X
1. A temporary scanner start up error.
2. This can also be the shutter tab on the print cartridge. Replace the toner cartridge.
3. Replace the scanner ***'y.
HP LASER PRINTERS 4200, 4300 ERROR 52.XX
1. Printer scanner speed error has occurred.
2. Replace laser scanner ***'y
3. Replace the D.C. controller ***'y
HP COLOR LASER PRINTER 4600, 5500 ERROR 52.XK, 52.XC, 52.XM, 52.XY
1. Error code K - No Black Color.
2. Error code C - No Cyan Color
3. Error code M - No Magenta color
4. Error code Y - No Yellow color
5. Replace laser scanner ***'y
6. Replace the D.C. controller ***'y
HP LASER PRINTERS 5000, 5100
4. Replace cable ***'y from scanner to D.C. controller.
HP LASER PRINTERS 8100, 8150
1.Laser scanner error/start up/rotation error
2.Replace laser scanner ***'y.
3.Replace D.C. controller board.
4.Replace cable ***'y from scanner to D.C. controller
HP LASER PRINTER 4500, 4550
1. Temporary error. Laser scanner error/start up/rotation error
2. Replace laser scanner.
3. Replace D.C. controller ***'y
HP COLOR LASER PRINTERS 4600, 5500
1.Laser scanner error/start up/rotation error.
2.Take the toners out and reseat them, or replace them
3. Replace laser scanner ***'y
4. Replace D.C controller board.
HP LASER PRINTER 8500, 8550
2. Replace laser scanner motor.
HP LASER PRINTER 9000
1. Temporary laser scanner error/start up/rotation error
3. Replace upper cable guide assembly.
4. Replace DC controller.
2answers
52 Scanner error
52 scanner error means yoy got got an error with the scan assy, it could be many problems. If it not helps with turn off /turn on, try reset the printer. Turn off power press and hold * and #, turn on power, wait 20 sec and release the buttons. If printer not goes to ready, disconnect power cord when printer initialize and turn off power switch. reconnect power cord and turn on power switch. If you get the printer to ready state, upgrade firmware.
33helpful
5answers
HP LaserJet 2840 Scanner Error
when poering on this HP 2840 it says" Scanner Error 5"
what does it mean? How to get a solution?
k24674
Grand Canyon Tech
Grand Canyon Tech
