Sounds like the DMD chip is on it's way out.
Check if the intermittent problem is related to the external air temperature. Try blowing cold air around the unit with a personal fan to see if it does the same thing.
Check if the air vents and filter is clean
DMD...
You need to change the DMD processor, the problem is that its come whit the optic unit. Optic unit (Engine) is expensive $490.
530-0227-00
OPTICAL ENGINE, SIMPLE IPD-S563 (W/O LAMP) IN2102 ROHS
