I forget my lock code after i on my cell phone nokia N82.I try to use the previous password but still cannot.Please help me to on as usual,so that I can use as normal.
A lock code is 5 digits long ONLY! Most default to 12345 or 00000. Unfortunately I cannot retrieve or reset your lost code.A lock code is 5 digits long ONLY! Most default to 12345 or 00000. Unfortunately I cannot retrieve or reset your lost code.
You can't post conmments that contain an email address.
Complete reset to factory settings? This will delete all your data currently on the phone. (that is included all apps installed and al settings) I hope you have a (not password protected) backup.
Just follow the instruction ..rate me if i help you thanks
turn off the cp, hold the following buttons ( call, * and 3 ) then turn on the cp without unholding the said buttons until the nokia logo ends.. hope it helps
Hello and Welcome on FixYa! The Default phone lock code of Nokia is 12345 or 00000. If you have changed thento get yourMaster code.Type *#06# at the mobile screen to know IMEI no of your mobileor you can also see the IMEI no after pulling out the battery, It is mention at back side of the mobile Then Go Here. Give your IMEI No there and calculate your master code and try it. It will work as your security codeIf it doesn't work too then you can get online paid security code for your cell. If you want to then you canGo Here. After getting your Cell info and charges, they will send you code. If you don't want to then you can contact to NOKIA SERVICE PROVIDER to get your phone lock code Anymore help, I am here to help If it is HELPFUL, Your Rating as FOUR THUMBS (Given below to this solution) and testimonial will be esteemed. THANKS and Keep Visiting FixYa
you should put your memory card in nokia s60v3 phone, like n78,n81,n82, etc. And then, unlock your memory card with standard code like 1234 or 12345. try it....
Phone lock codes are quite tricky to disable. especially for Nokia phones. Usually i would advice you try the default nokia code which is usually 12345 most times the code happens to be the default code. On the other hand if this code does not work the code for a hard reset *#7780# but note this will wipe off all your previously stored information. Make sure to remove your memory card before doing this. Hope this solution has been helpful?
