Toshiba Satellite A105 Notebook Logo
Posted on Apr 11, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The 17.1' display of my toshiba satellite P105 its broken, two white lines blocked de screen, and 1 half of de screen its blocked by blacki need the part number or de model of de display for replace my display
summer-ham
Level 1:
  • Contributor 2 Answers
  • Posted on Apr 23, 2014
summer-ham
Contributor
Level 1:
Answers
Questions
Helped
548
Points
On most Toshiba Laptops, there are 4 (covered) screws in the four corners of the bezel (frame) of the display screen. Remove the covers and the screws and gently pry off the plastic bezel. There should be some mounting screws that hold the display in place. Remove them and unplug the display. You can order a new display from an online computer parts store. Make sure to note the actual part number located on the back of your broken display as they can differ even with the same laptop model number. You can install the new display easily by reversing the above steps!
  • summer-ham Jan 13, 2015
    I'd do a google search with your part number! While links posted here might be helpful, you should always exercise your own due-diligence as the pricing and service can vary greatly from site to site. Best of luck!
Anonymous
Level 2:
Scholar:
  • Expert 62 Answers
  • Posted on Apr 12, 2011
Anonymous
Expert
Level 2:
Scholar:
Answers
62
Questions
0
Helped
18345
Points
196
Just a quick note, before you go replace the entire screen, make sure it's not just a wiring problem. If so, it doesn't cost as much to replace the wires connecting the screen to the laptop. LCD's are much more expensive!
As for replacing the display, this website has information on the display, along with the ability to purchase it from their site. http://www.pelltechnology.com/Toshiba/Laptop/Toshiba-Portables-Satellite-P105-Series-S6024/Toshiba-Satellite-P105-S6024-LCD-Screen-Replacement-P350475.asp
Hope this works!
Toshiba Satellite P105-S9722 white screen on stat up
Don't assume. Diagnose.
Problem could be graphics chipset, Video Cable, screen Inverter, or LCD screen.
Graphics chipset:
1) Laptop OFF, monitor OFF, connect a VGA monitor to the VGA port, on the laptop.
(Back of laptop - Blue)
Example of a VGA Cable, and a VGA connector, (Port on laptop),
http://en.wikipedia.org/wiki/VGA_connector
If you have a CRT type of monitor (Looks like a small TV), you can use it, or a flat LCD screen monitor with a VGA cable.
The Toshiba Satellite P105-S9722 Notebook PC, also has a DVI connector on the back of the laptop. (Next to the blue VGA port)
You can connect a flat LCD screen monitor with a DVI cable.
Example of a DVI Cable, and DVI connector,
http://en.wikipedia.org/wiki/Digital_Visual_Interface
2) Turn the monitor on. If a CRT type allow it to warm up.
Turn the laptop on.
By factory default the display should be on the external monitor.
If not;
Press, and hold down on the Fn key, (Bottom left), and tap once on the F5 key.
The F5 key is the Display Toggle-Over key.
You will see a list. It 'hot cycles' through the list, until you come to the external monitor device you are using.
http://shop.mcccomputers.com/network-modem-cards/6037-toshiba-satellite-p100-p105-p105-s6104-p105-s9722-video-board-256mb-ts15082.html
External monitor display shows no white screen?
Your graphics chipset is good.
Go on with the diagnoses.
Problem is with the Video Cable, or in the Display Assembly.
(Screen Inverter or LCD screen)
Video Cable:
The Video Cable attaches to the motherboard under the Switch Cover, and about at the F2 and F3 keys.
It then routes under the left Hinge, and up into the Display Assembly.
From there it connects to the screen Inverter, and back of LCD screen,
http://www.irisvista.com/tech/laptops/toshiba-satellite-p105/big/toshiba-satellite-p105-11.jpg
From;
http://www.irisvista.com/tech/laptops/toshiba-satellite-p105/take-apart-1.htm
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-P105-P100/remove-lcd-screen-inverter-1.htm
Due to normal opening, and closing of the laptop, the Video Cable may become pinched, and pulled on.
This can lead to a simple loose connection of the Video Cable TO the motherboard, or TO the back of the LCD screen.
(The screen Inverter connection should also be checked)
Visual inspection will NOT do. You need to physically see if you can plug the motherboard connection, and LCD screen connection in.
It could be just loose enough you won't be able to see it, but will affect the display.
Sheath of Video Cable needs to be visually inspected for signs of damage. Signs of damage to the sheath, may also mean damage to the tiny wires inside the sheath of the Video Cable.
(Stretched/Broken)
Assurance that the Video Cable is not the problem, means checking out, or have checked out, with a multimeter set to OHM's, to run a continuity check of all the wires.
('Mom and Pop' computer store. See if they will check it)
Or simply replace the Video Cable. (After you fire up the laptop, and see if loose connections was, or was not the problem)
http://www.batterysupport.com/toshiba-satellite-p105-s9722-cable-p-377633.html
(Left side connects to LCD screen. Right/Top connector goes to motherboard. Right/Bottom connector goes to screen Inverter)
Video Cable checks out OK?
Go on to screen Inverter.
http://www.ebay.com/itm/TOSHIBA-Satellite-P105-S9722-laptop-lcd-Screen-Inverter-/250759700669
The plastic thin frame in front of the LCD screen, is the Display Bezel.
The screen Inverter is behind the Display Bezel, and mounted at a location towards the bottom of the LCD screen frame.
A screen Inverter is tested with a sensitive multimeter. Read fairly expensive,
http://www.fonerbooks.com/test.htm
It is for this reason that those who do not have access to a sensitive multimeter, usually just replace the screen Inverter.
(Also low cost, and ease of access to replace)
Screen Inverter checks out OK?
Problem is the LCD screen,
http://www.amazon.com/SATELLITE-P105-S6084-P105-S9722-P200-140-REPLACEMENT/dp/B007QEEYGE
For additional questions please post in a Comment.
Regards,
joecoolvette
[ Bet it's the video cable, or screen Inverter, that is the problem ]
[ Primer:
An LCD screen cannot produce light by itself. It needs an additional light source.
A Backlight is the additional light source.
A Backlight can be a CCFL, (Or two of them), or a series of LED's.
(Light Emitting Diode)
The Toshiba Satellite P105-S9722 Notebook PC, uses One CCFL for a Backlight.
A CCFL is a Cold Cathode Fluorescent Lamp.
Similar to Fluorescent lighting used in homes, and businesses, but on a MUCH smaller scale.
Average thickness is 2mm. That is a little larger than 1/16th of an Inch.
Average length is almost as long, as the LCD screen is in height,
General example,
http://www.laptoprepair101.com/laptop/2007/12/09/replace-laptop-backlight-ccfl-lamp/
A CCFL contains -> Mercury, just like Fluorescent lighting used in homes, and businesses.
A screen Inverter is used to convert the power from the laptop, for the Backlight, and LCD screen.
90 Percent of the Time the fault is a bad screen Inverter.
Primer over.
I have Toshiba SATELLITE P105-S6197 Laptop and suddenly a horizontal while/grey lines appeared as a strip and after windows login it appears as a black strip at right side
Sounds like a bad screen. The easiest way to verify that would be to attach this to an external monitor (at work, a friend's ... if you ain't got one) - if the external monitor apprears good then you've pretty much iso'd the problem to your laptop's screen. This model uses a 17" widescreen. Best place to buy 'em would be on eBay, and they'll usually run around $90 to $100 if you need one right away - half that amount if you've got time and patience :-)
Flickering screen Toshiba P105
Flickering, always cause by LCD cable. Change it at any computer shop or service center and its not so expensive
My monitor started showing vertical lines, first a few then half the screen. Now, half the screen is black.
Your Laptop screen has either too much of Moisture in it or the display circuit at the laptop folding place is creating issue. Please take the machine to Toshiba Service Centre and they will do the needful. Any attempts to fix the problem by yourself will worsen the problem and respond quick.
My Toshiba p105-s6064 display screen is only showing half of my desktop, the other half goes black or flickers various colors. Do I need to replace the display screen or the video card?
Try connecting to an external monitor if display screen is only showing half of my desktop, the other half goes black or flickershalf of my desktop, the other half goes black or flickers various colors then it is the video card if not....have ur display screen changed.
EXACTLY the same problem.
This is a common lcd issue. The pcb board in the lcd is defective (cracked or broken). The only way to fix it is to have the lcd replaced
Toshiba Satellite P105-S6124 Screen lines
Are these lines on the screen during the whole boot process? If so then the screen cpu and/or the video cpu has gone bad. Connect an external monitor. If the picture is clear, no lines, then the problem is the LCD screen. If the lines appear on the external monitor during the boot process then the mother board will need replacement.
Good Luck
White lines
Did you try lately to go to your display settings and change your screen refresh rate ?
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
