Hello & Welcome to FixYa
Flashing light is reset by pressing two buttons in sequence 3-4 times, to reset your dishwasher press these buttons in sequence:
High temp wash-heated dry-high temp wash-heated dry
Please get back to me if you have any other questions.
Kevin
If the clean light flashes 7 times it's an error code telling you that there's a heat problem, it will be either the heater or computer board is bad,if you remove the bottom kick panel you'll find the tech sheet inside the plastic bag,it will tell you how to read out the heater from the board,if the heater is good most likely the board is bad.i see people just resetting the board,yes it will run but after 7 loads it will start over again,it's an error code
SOURCE: Kenmore ultra wash quiet guard 3 dishwasher problem
The sequence of "Press Heated Dry, press Normal Wash, then press Heated Dry again and press Normal Wash again (that's 4 button-presses)" worked for us. Many thanks!
