Jenn air cook top
Yes you can. Call Jenn Air ((877) 232-6771) and give them your model number (serial is helpful too). They sent my replacement glass within a week. I have a model JED8430ABD from 2000 and they had the top. Fit perfectly and took about an hour to replace.
To change it out, after unplugging the cooktop, I removed the metal tape connecting the external vent shaft to the blower. Then I just lifted the entire cooktop out up out of the countertop so I could access the screws on the sides of the cooktop (looking at the edges of the new cooktop glass helped me figure out which screws to remove around the edge). Then I removed the 2 screws in the vent area on top (1 black screw on each side). And that released the cooktop glass from the metal box that holds the burners. I then took the rubber rings out of the knob holes so I could put them in the new cooktop (I almost missed that...). Finally, I put the new cooktop glass on, put the screws back in, lowered the cooktop back into the counter, and retaped the blower to the vent shaft. Voila!
I really wouldn't be afraid of doing this yourself if you are handy at all. And it will save you a ton. Good luck.
PS The screws around the perimeter are hexigon shapped, so you can't just use a screwdriver. I found my Black & Decker electric screwdriver had that same shaped hole that it held the bit, so I just pulled out the bit and used the screwdriver that way. Worked like a charm.
