SOURCE: Everything freezes in the refrigerator
Your damper that controls the air to the fridge side is stuck open. It can be caused by moisture getting on it and freezing it so it wont close or by a failure in the electrical circuit that controls it. There was a service bulletin from about 3-4 years ago about defective control assemblys. I have replaced several and as far as I know Frigidaire is still replacing some of them for free if they fall under the model and serial numbers that were affected.
You can tell if it is frozen by turning the controls off and thawing the damper at the upper left rear of the fridge section with a hair dryer.. After you have it thawed out, turn the controls back on and you should hear the damper door motor running. Keep your thermometer in it and check it after a while and see if it shuts off before it freezes.
Post back with the complete model and serial numbers and I will try to locate the service bulletin at my shop computer tomorrow.
SOURCE: Samsung RS2556 - Refrigerator side is not cooling - Freezer is fine
I have RS2555 in same problem.my warranty is expired and Samsung hooked me up to an technician who asked for 300.00 for labor plus parts and tax, what a rip off!!I I called my Canadian friend who's a technician and I was told to POWER OFF the RS2555 for 24 hrs.both doors MUST open and take out all drawers,he said ,it is 90% the ICE blocked the cool airflowing,so if ICE melted,all will return to normal.
It works after I did what he said.share this and hope can help some one with same problem!
SOURCE: refrigerator not cooling
Open the panel in the freezer, and take a hair dryer to the frozen coil.
SOURCE: Temp
I've had my Samsung RS267 LASH side by side for almost 2 years now and the coils froze recently. The temperatures displayed - relating to the refirgerator side - bounce around when the coils freeze. My freezer thank goodness is still working properly. The repairman indicated that the heating element for the refrigerator coils was bad. Unfortunately he had to order the whole unit (coils, heating element, etc.) since he couldn't replace just the one part. Samsung takes their time sending the parts - we've been waiting for 10 days now. The Samsung warranty covers the compressor, evaporator, condensor, drier and connecting tube for 5 years parts and labor so we should becovered. You might be covered as well - depending on when you purchased your refrigerator. I did purchase a separate extended warranty from Lowes when I bought the refrigerator and I'm glad I did. My extended warranty included $250 in food spoilage covering our food loss due to the breakdown. Hope this helps......
SOURCE: samsung rs2533sw fridge not cooling
it sounds like the refrigerator evap is frozen up causing the compartment to get too hot. shut the unit off and let it thaw out. then take the screws out of the cover to check the stryrofoam on the back side of the cover to see if theres broken spots on it causing the air to bypass the evap causing it to freeze. Theres two screws behind the light cover and two at the very bottom of the cover and two behind the decorative plugs about 1/2 way
