SOURCE: Hitachi BX37E error
You can try to clean the laser lens first with a q-tip and 99% alcohol. If that fails, you should take it in for repair because the laser lens mechanism may be out of line because of a bump. There may also be a dust build up inside that prevents the proper movement of the lens. This can be done at home too.
SOURCE: Describe your Hitachi DZ-MV580A DVD Cant Read Discs ERROR 2881
here is the instruction manual for it,go through it carefully and u will find the sol.
Click here to download
Goodluck,
Dont forget to rate me as fixya..
Yesterday I filmed with Hitachi camcorder is DZ-GX5020A in back yard, I am actor and press the record is half hours. Camcorder causes "Repair Data" x Found error in image file. Repair data now?" I press the "Yes" is for 6 second is pop screen said " ! Use AC Adapter/Charger. Turn off power". I unplugged the recharge battery and use Ac Adapter with plug in the camcorder is turn on(I click turn on behind of camcorder on film logo) on "DISC ACCESS" then pop screen said "Repair Data" x Found error in image file. Repair data now?" I re-click on "Yes"(like before use battery pack recently) is 19 second on "Repairing" on pop screen repeat again on it's said "X Error occurred. Please Replace disc." I press square make stop. Then check said "DISC ACCESS" Then I press record because it's said "CHECK DISC" doesn't working. I believe the Hitachi camcorder cause damage on disc is erase, malfunction problem cause damage or security something. When I filmed my niece Anna Maria's B-day, Disneyland, etc. are last week agothen I am actor are filmed inside of the mini disc is very important, I tried on Finalize doesn't working cause said "Finalize Disc...! Write protected. Check disc" cause block by Repair Data's security on disc. I disabled security of Repair Data. Unknown. I am very very very angry, depression, disappointment. I am just angry at Hitechtronic, Inc. should responsible, tester, design who make camcorder should be better quality. Can you repair my mini Disc "Memorex "should disabled security of Repair Data? Something please help me for switch your camcorder is different brand out my mini disc on finalize and back to me?. Can you ask tech should fix my mini disc on finalize uses on the other camcorder (borrow is temporary) make finalize? Then back my mini disc (very important) on tech had other Hitachi camcorder is DZ-GX5020A should finalize is very simple. I am very confuse or what.??
From
Juan Antonio De La Torre
