Question about Sony Ericsson K800i Cellular Phone
My k800i has a blank screen, only white and its keep blinking, also when i charge it, it will only keep blinking kindly please help, what should i do first, change the lcd, change the battery or go to repairer. i have a personal picture and i dont want the repairer see it, any suggestion? thanks
SOURCE:
  • 452 Answers
SOURCE: whit screen
Try with the new battery and check it works or not.Otherwise consult hardware vendor for the same.
Posted on Nov 12, 2007
vascotech
  • 93 Answers
SOURCE: problems with sony ericson k800i
There is a problem with your firmware. It seems that your software became corrupt. It happens all the time on Sony Ericssons. Bring it to your local cellular service center and they should be abale to flash it for you on the site under warranty. If you run into any problems, look in my profile and i can probably help you out.
Posted on Jan 23, 2008
SOURCE: K800i phone just turn into white screen
there might be a short circuit in charging.
this thing happened with me also .
but when i removed my cell restated it is working fine..............
Posted on Dec 09, 2008
  • 56 Answers
SOURCE: k880i white flashing screen
White Screen Of Death. Quite common on Sony Ericsson phones. My K800i does it every time its battery shuts off while it's on (so I try to make sure it doesn't). You need to (google terms) reflash sony ericsson phone Maybe also first backup GDFS The photos, except those on the memory card, and other stuff will be lost, I'm afraid. But good news is that your contact list can likely be saved by backing up the GDFS.
Posted on Jun 10, 2009
Z00T
  • 76 Answers
SOURCE: my sony erricson K800i is stuck...i get only white
You need to flash the phone with correct firmware. join this forum (free), you'll learn how to flash, unlock, debrand and mod your SE phone. http://forums.se-nse.net/index.php?s=cb3baa5dabe210ea073e3b56aa6ff209&act=idx (copy and paste in browser)
Posted on Jun 16, 2009
Phone goes blank
sir is it blinks with white screen only or blinks with white screen then shut down?
-if the phone can receive/send text and mms messages while the incoming and outgoing calls become shut down,i think you need to replace the battery because it is weak.use only original battery.
-and if it is blink with white screen only try to reset all settings or reformat your phone,if not work hardware problem go to repair shop.
Dec 26, 2009 | Cell Phones
K880i white flashing screen
Mar 24, 2009 | Sony Ericsson K800i Cellular Phone
Blank screen
Remove the keep the battery out for 5 mins. Press the power button for 30 seconds without the battery to drain any charge on the main hardware.
Reseat the battery and turn on the phone.
Jan 26, 2009 | Sony Ericsson K800i Cellular Phone
Hi , I am ravi. I have a K800i sony erriccson mobile phone. The screen has just gone blank and is emmitting white light. There is no display at all. Can you help me please. Thanks
I did not get any solution from the Forum. I went to the sony ericsson web site, clicked support,downloded the UPDATE SERVICE on my computor, followed instructions step by step and the problem got solved.
Sony ericsson k800i Not turning on
I had a similar issue, whereby my phone would turn on for 30 secs then the screen would go white and the phone would switch it self off then on.
After a lot of messing around even throwing the phone around the place. I took out the memory card and the phone worked fine. When I put the card back in, the phone started misbehaving again, so I guess the card is knackered.
Dec 30, 2008 | Sony Ericsson K800i Cellular Phone
Blinking white blank display after turning on
Try resetting your tomtom by inserting a paper clip through the reset hole found underneath. One quick press is all thats needed. Charge the tomtom first now and then switch on after its had a good charge.
If this doesnt work , please reply again and i'll try and help further.
Good luck
Nov 08, 2008 | Tomtom ONE GPS Receiver
Sony ericsson k810i
my sony ericsson k800i phone has no menu how do i reset menu please help
Jul 15, 2008 | Sony Ericsson K800i Cellular Phone
I can only see blank screen on my k800i, cant even turn it off unless take the battery off
i can only see a blank screen on my k800i with vibration, and i cant turn it off unless take the battery off.
Apr 22, 2008 | Sony Ericsson K800i Cellular Phone
Problem with new mobile
If you can try another fully charged battery, in your phone and it works then it might be a dodgy battery problem. leave the phone off to charge the battery for 10 hours and see if its better.
Dec 26, 2007 | Sony Ericsson K800i Cellular Phone
Sony Ericsson K800i Cellular Phone Logo
Top Sony Ericsson Cell Phones Experts
Damen Wong
Damen Wong
Marvin
Marvin
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
