MY DEAR FRIEND
CAN you tell me the what is the display problem
OK
Motherboard problem motherboard can't display when switch on, the cpu fan faster no beeping . I had change power supply, but same.Check the keyboard LED,Not flash.I had remove the ram but can't hear beep. PC speaker ok conferm. Monitor display tested monitor its ok . But no comming display. Can you help me? How i can solve this problem?
I believe you hear the fan, the harddrive and other components of the computer run but the display shows you only a black screen.Here's the checklist of what you need to do.
For desktop computers:
For laptops:
Hello lok,
May be the cell of the motherboard gets finished.
Replace the new cell and the display will come.
laptop or desktop ??
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them they might be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electical extensions even something as small as an electrical fan and its lead can cause this problem
just replace them they could be faulty a computer needs all electrical power and data to continue through every working device and to have an end so any faulty leads will end up with a computer error
make sure your graphics card is securely seated with no dust built up or in the socket
hope this helps you
