http://www.hifi-remote.com/ofa/codes-tv.shtml#tvIf none of the codes work then we have two other solutions:
1. Searching For Your CodeIf
you have tried all of the set-up codes for your brand of equipment ,or
yourbrand is not listed, and you are still not able to get the unit to
respond, trythe following procedure to search for your code.
If
you don't find a code that works, the remote will flash four times when
youreach the end of all the codes for this device type.
- PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
- PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
- ENTER 9-9-1 (two blinks on the remote)
- ALTERNATE slowly between the POWER key and
the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off.
(On VCR, LD, and CD players use PLAY instead of POWER)
Make sure
that the remote is pointed at your device during the search, You may
have to press this sequences of buttons up to 100 times to search the
entire library of codes.
- When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the originalLine up your original remote and the head-to-head before completing thefollowing steps.
- PRESS and HOLD the SETUP button until the red LED flashes twice.
- PRESS 9 - 7 - 5, the red LED will flash twice.
- PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
- PRESS the button that will receive the learned function, the LED will flash rapidly.
- PRESS the button on the original remote to be learned.
Now
you can repeat steps 3 through 5 to learn other functions onto other
keysor press and hold SETUP until the Cinema's red light flashes twice
to lock inyour new feature. (If the red light does not blink twice,
stop and repeat stepsthrough 6).
To test the new feature, press and
release the device key in which the newfeature was learned followed by
the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#deviceHope that helps! Should you have any further questions,please feel free to post them here.
Television
Video - DVD Audio Satellite Set Top Box Video - VCR Brand: Model (optional):
We could not find an exact match, we think this code will work. 10054
Setup Instructions · Set the "Mode Switch" to TV.
· Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
· Enter the 5 digit Code above.
· Try your new code and tell us how it worked!
You'll have to settle for that, use the middle power key in the tv device to power on & off the tv.
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
