The owners manual will tell you what you need to do. Did you try to put the key in the drivers side door and lock and unlock it? If that doesn't work try doing the same thing to the passenger side door.
Put ear plugs in (ha!) and hook up battery enter car turn key to on and hit brake pedal, now start car should fix.
The body control module (BCM) commands the horns on. The BCM commands the horns on under either of the following conditions:
When the content theft deterrent system detects a vehicle intrusion. For further information, refer to Content Theft Deterrent (CTD) Description and Operation in Theft Deterrent.
When the panic button is depressed on the remote control door lock transmitter. For further information, refer to Keyless Entry System Description and Operation in Keyless Entry.
When the OnStar?® system is used to sound the horns, if equipped. For further information, refer to OnStar Description and Operation in Cellular Communications.
When the keyless entry system is used to lock the vehicle, a horn chirp may sound to notify the driver that the vehicle has been locked. The notification feature may be enabled or disabled through personalization. For further information, refer to Keyless Entry System Description and Operation in Keyless Entry
