Unfortunately, there is no compatible driver for win 7. THe Mustek support center says the following: Scanners designed to work with older versions of Windows may not function
properly after upgrading your computer's operating system.
If Windows® 7 is not listed on the product driver download page for a
specific product, no support is offered for Windows® 7. Newer scanner products
available will have support for Windows® 7.
There are no Windows 7 drivers for that scanner but you can try this trick:
Download the newest XP drivers from this site:
http://www.mustek.com/mustek/supportdrivers.php
Get the one file installation.
You will not be able to install the drivers but you can trick them to work.
The procedure is simple:
Do not plug in the scanner, start up the
Empty your systemrootwindows emp folder
Srart the instalation and when it asks "Select Language" stop there. Then copy the all contents (files and folders) of WindowsTemp to another folder (e.g. systemroot1)
Then plug in the scanner and windows should be able to find the drivers there if not guide it to that location and let it install Mustek Twain drivers.
However, you could try downloading MUSTEK Scanexpress 1200 UB Scanner drivers for Windows Xpand try running them in compatibility mode. click here how to run them in compatibility mode
y all this does not work you must have to contact manufacture for better support.
hope this help
Hello leonardopeli
Unfortunately, Mustek offer no Windows 7 support for this model.
What version of Windows 7 are you using? You may be able to install the scanner in the virtual XP which comes in-built to some versions of Windows 7.
ajblaj
If you have the cd that came with your bluetooth device then insert it in the optical drive and run the program. If not, then go to the manufacturer's support website and download the driver for your type of Operating System.
copy the entire set up cd to your hard drive into a folder, then right click on the setup file, select properties, then the compatibilty tab, then check the box "run as" and select the compatable version
