SOURCE: Little Giant stopped working; makes hum noise but wont push wate
Can you take it out of where it is and clean it with vinegar? There may be calcium built up in it. I have one also on my aquarium and when I turn it off sometimes it won't start back up, just humms.. That tells me it's time to clean it.
SOURCE: I want to replace an impeller for a Little Giant submersible pump
This is a plastic impeller on a brass hub. If the impeller is loose it is probally cracked or overheated and melted, ether way you will have to break the impeller off of the hub then you will need to break hub loose from shaft. You can do this by putting pump in a vise and putting a pair of vice grips on hub and giveing them a sharp hit in a counter clockwise direction. you will need to replace the seal and impeller and should check to be sure than you can get these parts before you start.
SOURCE: little giant pump stopped working
Hi Tom (and Lindsay?),
Ok lets get a little more info,
Please comment back with your findings
Mike
