Check thid procedure... Removal & Installation
Fig. The location of the generator on the 2.7L Engine
Fig. The location of the generator on the 3.2L and 3.5L engines
2.7L Engine
To install:
Negative battery cable
Lower plastic splash shield
Transmission cooler and position it aside
Lower radiator crossmember support
Adjusting -T- bolt and the pivot bolt
Drive belt adjusting bolt
Drive belt
Alternator field circuit plug
Alternator B+ terminal nut and wire
Pivot bolt; be careful not to lose the spacer
Alternator
Alternator
Pivot bolt with the spacer and leave loose
Alternator B+ wire and terminal nut; then, torque the nut to 89 inch lbs. (10 Nm)
Drive belt
Transmission cooler
3.2L & 3.5L Engines
To install:
Lower mounting bolt and pivot bolt
Drive belt tension bolt
Drive belt
Bracket, lower mounting bolt and pivot bolt
Alternator
Alternator
Drive belt
Pivot bolt and lower mounting bolt
Hope this helps (remember to rate tna domment this answer).
SOURCE: need to change the alternator
REMOVAL & INSTALLATION
3.3L Engine:
To install:
3.5L Engine:
To Install:
If you need photos to follow then try this link...
http://www.autozone.com/shopping/repairGuide.htm?pageId=0900c1528006a83e
SOURCE: THERMOSTAT PICTUREDIAGRAM OF 1999 DODGE INTREPID, 2.7 ENGINE SIZE
Thanks for your help. But I got the answer that I need.
SOURCE: need to install an alternator
2.7L Engine
To install:
(The location of the generator/alternator on the 2.7L Engine)
3.2L And 3.5L Engines
To install:
(The location of the generator/alternator on the 3.2L and 3.5L engines)
Hope this is what you were looking for.
SOURCE: find location for oil filter for oil filter for dodge intrepid
What engine? 2.7 passenger side on the bottom next to oil pan. 3.2 and 3.5 Drivers side coming off the side of block, near the front under the exhaust manifold.
SOURCE: changing the water pump on a 1999 dodge intrepid
Good luck! I can't type out the entire process but you need alot of tools,some chrysler only tools,a good manual,since you never did it before,coolant,the pump,new timing belt,a torque wrench for the timing belt tensioner,etc. Leave it to a pro.
