SOURCE: lyra rd2840
as far as a replacement battery, I soldered in an ipod battery with the same specs as the RCA, turned out the be the same size and a perfect fit in the case.
SOURCE: my mp3
i have what you need email my at [email protected] and i will email you the files and you have to put them back on do not delete them or your player will not work
SOURCE: rca lyra rd2840 firmware download
Check the follwing sites:
http://drivers.softpedia.com/get/FIRMWARE/Lyra/
http://www.drivers-software-download.org/tag-download-lyra/
http://www.downloadtube.com/Drivers/Firmware/Lyra/
By the way, the only I did just was Google the internet and look for "RD2840 firmware download"
Best regards,
SOURCE: the RCA Lyra 1090a says bad or missing lyrasys
What i do is i never put songs in my internal memory...this way you never have to worry about formating the internal memory....so i have several exteral card i use say one for country or rock and its so easy to format a exteral card just place it in ur card reader if ur using a laptop them go to my computer right click on ur card that youll find then youll notice on the list theres format so its so easy...im sure its asking you to format ur drive because you must have a few corrupted files....best of all when adding music just pull ur external card out place it in a reader fill ur card with music then insert it back in ur device...this way ur getting away with using any firmware....by the way take any disc that came with ur Lyra and chuck it in the garbage that 90 percent of all ur problems
