Cell Phones Logo
Posted on Apr 09, 2011
I have a new pc with windows 7 and i can not install the cd for my phone so i can download my photoes. error message publisher not specified
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 15 Answers
  • Posted on Apr 09, 2011
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
15
Questions
0
Helped
1032
Points
48
I am going to provide general information because the model of the phone was not specified.
If the phone connects via USB it will most likely automatically be recognized by windows 7 as a usb mass storage device. simply navigate to the DCIM folder and extract your photos. if you could provide specifics i could give you a more definite answer.
Cannot open ascddmi.dll
When I look at the ASUS site to download drivers for Windows 7 - there are none. So if you are trying to install drivers from the CD, you do not need them for Windows 7. There is a utility which you can install - check this site.
https://www.asus.com/Monitors_Projectors/VK248H/HelpDesk_Download/
2answers
Hi, I have used printmaster premier 7.0 for a few years on my old computer and have loved the program. The problem I am having is I bought a new computer that runs windows 7. I tried to install printmaster...
the problem is that windows 7 is not compatible with Print-Master premier 7.0
The program cannot run on windows 7 because it wasn't programmed for it. This is why the error message comes up.
There is nothing you or anyone can do about this.
Sorry about this.
Regards.
2helpful
My program photo explosion deluxe version 3 will not opened when downloaded to my new computer that operates windows 7. what should I do to get this program workining, I do not like version 4 of photo...
Hi!
What I understand is that your photo explosion deluxe is a windows xp software. Since it is not working readily out of the box in windows 7 then what you could do is install windows xp mode for windows 7. Windows xp mode allows xp software to be installed and windows 7. What you need to do is just download windows xp mode and install it. After which you could then install that software on there. Just make sure to uninstall your current installation of photo explosion deluxe before you do this.
Here is the link to the download for windows xp mode: http://www.microsoft.com/windows/virtual-pc/download.aspx
And Here is the link to some of their videos on how to use xp mode so that you could understand further how to set it up: http://www.microsoft.com/windows/virtual-pc/support/default.aspx
If you have any more questions or concerns please feel free to come by again here at fixya.com
You have a great day.
This used to work perfectly on windows XP. I now have windows 7 & after downloading the Photo Explosion 2.0, it won't open & the programme just freezes. Help.
Downloading means you retrive any files and save to your PC/Laptop from any web source!
Installing means you install any software/programs to run on your PC/Laptop.
As for your software "Photo Explosion 2.0" could not run on Win 7 due to software "Compatibility Issues".
You can try, using "Win 7 compatibility mode" installing older software read this LINK
NOTE**
"There is no guarantees older software will work using Win 7 compatibility mode!"
Hope it helps.
I am trying to install my old software on my new computer. After hitting the "Install personal patterns for children - special edition" I get an error message stating: could not execute external program...
Open "My Computer".
Double-click the icon for the CD-drive.
Look for that 'ppchild' file.
Or, look for an 'setup' file or an 'install' file.
Double-click one of those files, to restart the installer.
If it still fails, then your new computer (running Windows 7) probably has recognized that the program is _NOT_ compatible with Windows 7. So, start the Windows "Program Compatibility Wizard", and tell it that you want to install a Windows XP program on your new computer.
I can't get iTunes to load on my PC. I downloaded the program from Apple's website. It downloaded fine, said that it was successfully installed on my computer, however when I try to open it, I get an error...
With this one you have to follow these articles fully and do all the steps even the ones in blue - follow theses steps you should be fine !
if not re-post with what happened- I will help you .
Windows vista, 7
Windows xp
1helpful
I cannot install Roxio ez cd creator platinum on windows 7 comput
you may try calling the manafacturer and see if you can activate it over the phone. They should also be able to register your software at the same time.
1helpful
ERROR MESSAGE AFTER INSTALLING MY LEXMARK X6650 PRINTER
Hi. That error pops up when you're using an installation cd that runs on Microsoft .Net Framework Version 2. Unfortunately, Windows 7 doesn't have that. Make sure you don't have the Lexmark installation cd in the computer. Eject the installation cd from the computer. Restart the computer and check if problem still persists. But if there's no cd in the computer and you have tried installing the software using the cd the first time, uninstall the Lexmark software by going to Start Menu > Programs > Lexmark 6600 Series folder > Tools > Uninstall. Reboot pc. Reinstall, this time, using the same installer you downloaded from the Lexmark website only. Don't use the installation cd. Hope this fixes your problem.
1helpful
2answers
I have the following message and I understand the problem may be with Adobe Photoshop Elements 6 The appplication has failed to start because connAPI.DLL was not found. Re-install may fix the problem
Hi there.
Do one of the following solutions: Solution 1: Remove the NOKIAManager.mox file.
  1. Exit Photoshop Elements.
  2. Open the C:\Program Files\Adobe\Photoshop Elements 6.0\moxplugins folder.
  3. Move the NOKIAManager.mox file to the Recycle Bin, or another location such as your desktop.
  4. Restart your computer.
Note: The NOKIAManager.mox plug-in file is required for Adobe Photo Downloader to download photos from a Nokia mobile phone. If you use a Nokia mobile phone, use Solution 2. If you later decide to use a Nokia mobile phone, either move the NOKIAManager.mox file back to the original location or reinstall Photoshop Elements.
Solution 2: Install or reinstall the Nokia PC Suite software.
Note: Only use this solution if you connect a Nokia mobile phone to your computer.
In order to communicate with a Nokia mobile phone, your computer must have the Nokia PC Suite software installed. Install the software to allow Adobe Photo Downloader to communicate with the phone and download photos from it. If you have previously installed Nokia PC Suite but are still getting this error message, uninstall and reinstall the software or upgrade to a newer version. For more information about Nokia PC Suite, contact Nokia or visit the Nokia web site.
Solution 3: Disable Adobe Photo Downloader.
  1. Open the Organizer in Photoshop Elements.
  2. Choose Edit > Preferences > Camera or Card Reader.
  3. Disable the Auto Launch Adobe Photo Downloader On Device Connect option.
  4. Click OK.
Note: This solution will prevent Adobe Photo Downloader from starting when Windows starts, and it will not appear automatically when you plug in a camera, card reader, flash memory drive, or other memory device. When you plug in one of these devices, and in order to download photos into the Organizer, you will need to start Photoshop Elements and choose File > Get Photos or Videos > From Camera or Card Reader.
Good luck and thanks for using FixYa!!
Top Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
 Mikey
Mikey
Are you a Cell Phone Expert? Answer questions, earn points and help others
