Benq monitor
shared by 2 users
posted by Kantar on Aug 06, 2008
only displays the benq for a split second. you said something about a capacitor. the only trouble im getting is getting inside to check it out. and could it be the lamp?
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Posted by auplpnb05 on Nov 13, 2008
I have the same problem. The transistors have been checked - ok. The transformers have been re-soldered. Still have the same problem.
Best Solution
posted on Sep 01, 2008
FixYa! (100)
viziks
Rank:Wiz Wiz
Rating: 84%, 168 votes
Most of the time problem is Invertor transistors being defective and Inverter transformer dry solder.
But you must be technically able with soldering skills and be able to test transistors using a multimeter.
Samir
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Benq monitor:
I don't want to Accept this solution
Can you Help with these Monitors problems?
Monitors
monitor was working when i bought it, used, it sat for...
Monitors
My power went out last night (monitor was plugged into a...
BenQ FP737S-D (Black, Silver) 17" LCD...
?ve tried downloading a driver but it didnt work
thanks for help, i dont think id trust myself to try...
Remove mains and reconnect, usually ok for a while..
Loading problems.
Need Immediate Assistance?
Chat Live Now!
Top Repair Providers for
Computers & Laptops
(888) 430-9744
Computer Repair Over The...
OverNetUSA
(412) 715-4340
We will fix all d-link or linklsys wireless...
ATCS Incorporated
Prescreened Contractors
Get Matched to Prescreened Computer Professionals
Category
Zip code
X
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
