Question about Canon PIXMA MP530 All-In-One InkJet Printer
Canon MP530 "Inner Cover Open"
I've tried all of what the others had done, and every time i try to copy or print i hear a clicking noise and the code reapears. I cna reset it by hitting the stop/Reset key. and all over again the code comes back up. The flap in the bypass area is in the up position. Please help me with this. and I'll love you forever. Thank You Very Much
SOURCE:
SOURCE: Canon MP530 error code "5C10" ?
I had a similar problem. I replaced all the ink cartridges and cleaned the printer.  I checked the nozzles to be sure that they were clean and cleaned the area where the cartridges set.  It took a little while but my printer is working again.  Mine makes a clicking sound after you push the copy button but still pulls the paper through.  Does yours pull the paper through at all?
Posted on Oct 22, 2007
IB4G2008
  • 3587 Answers
SOURCE: canon MP600 printer
sounds like the inner cover is not seating properly. so, perhaps there is something amiss inside, making that cover not latch cleanly? do a visual inspection(got one of those dental type mirrors?).
Posted on Mar 10, 2008
SOURCE: error is inner cover is open.
I have had this error message and no matter what I do, the message won't clear and the printer will not operate. I have closed the "inner door", powered down, even unplugged it from the computer to reset. The message will clear when I restart, but as soon as I try to copy or print, it looks like it will work, but then I hear a slight click and the message comes back. The door isn't open, but something is communicating that it is. Anyone else have this problem?
Posted on Jul 31, 2008
huntwolfe
  • 20 Answers
SOURCE: Canon Pixma ip3000 flashing amber 6 times
If the 6 flashes are accompanied by an on screen message #5400, this is a "Service Call Error" code.
This code indicates the following;
Internal temperature error [5400]
The solution to this is the following part replacementl
- Logic board ***'y (QM2-1548) *1
*1: Before replacement of the logic board ***'y, check the waste ink amount (by service test print or EEPROM information print). If the waste ink amount is 7% or
more, also replace the bottom case unit (QM2-1205) or the ink absorbers (QC1-4222 / 4223 / 4224 / 4263 / 4264 / 4864 / 4221 / 4257) when replacing the
logic board ***'y.
[See Section 3-3. Adjustment / Settings, (6) Service mode, for details.]
Good luck!!!
Posted on Oct 02, 2009
  • 1335 Answers
SOURCE: getting "inner cover is open" message
The inner cover is a flap on the inside in front of the carriage when it is at rest when the cover us open. You had to flip the inner cover down to access the ink cartridges.
Open the cover. The inner cover is in the center and need to be flipped up.
Good luck.
Posted on Dec 05, 2009
I have tried replacing all ink cartridges with brand new ones but it keeps saying Error U052 ? I am not really sure why it won't recognize the ink cartridges especially because they are from Canon
The error code indicated, the print head is defective, so it will not get solve by replacing any number of cartridges. Just follow the steps below to reseat the print head, if that does not help, then replace the print head.
  1. Confirm that the printer is powered on and press the <Open> button. (The paper output tray will open.)
    *MP800R shown
  2. Lift the scanning unit (printer cover) completely. (The print head will move to the replacement position.)
    Note: When the scanning unit (printer cover) is opened more than ten minutes, the print head moves to the right side. If this occurs, close the scanning unit (printer cover), and open it again.
  3. Open the inner cover.
  4. Remove the ink tanks by pressing the tab of each tank.
    Caution: Handle the ink tanks with care so that your clothes and surrounding area do not get soiled. Make sure to remove the ink tanks one by one.
  5. Raise the print head lock lever.
  6. Tilt the print head slightly towards the front of the machine and lift out gently.
    Caution: Do not touch the print head nozzles <1> , electrical contacts <2>, or ink supply ports <3>. Doing so may cause printing problems.
  7. Place the print head in the print head holder and lower the print head lock lever carefully until you hear a click.
  8. Insert ink tanks into the print head.
  9. Press the mark <PUSH> on the ink tank firmly until you hear a click.
  10. Ensure that all the ink tanks are installed properly and the ink tank lamps light red.
    <7> The ink tanks are installed properly.
    <8> The ink tanks are not installed properly.
    Note: Click for Ink Tank Lamp indications.
  11. Close the inner cover and the scanning unit (printer cover).
    Caution: When closing the scanning unit (printer cover), be careful not to jam fingers.
    N
    ote: The next printing begins, the print head cleaning will begin automatically.
You can check the status of each ink tank according to the way its lamp flashes.
- On: The printer is ready to print.
- Slow flashing (at about three second interval): Ink is low. Prepare a new ink tank.
- Fast flashing (at about one second interval): Ink tank is empty, or the printer is not ready due to an error.
- Off: An error has occurred and the printer is not ready to print.
Aug 28, 2012 | Canon PIXMA MP530 All-In-One InkJet...
When i turn on the printer i get a message saying error code 6500, the main carriage doesn't move at all, no response at all, all can get is the alternate blinking of LED's 20 times both blue and orange
First try this:
Reset the printer:
1. Turn the printer off with the Power button (if available).
2. Disconnect the data cable from the printer.
3. Unplug the printer's power cord for approximately 10 minutes, and then plug it back in.
4. Turn the printer back on. If this works you're done, if not try the next step.
1. After confirming that the printer is powered on, open the paper output tray.
2. Open the top cover and wait until the print head moves to the center.
3. Open the inner cover and check that ink tanks are properly seated.
4. Properly seated
5. Press down on each ink tank until a click is heard.
6. Close the inner cover and top cover.
Mar 03, 2011 | Canon Computers & Internet
Canon mp530 error 6500
The 6500 error code is a logic board error code. The PCI Bus error is detected by the ASCI. Sounds like it needs new logic board. Solution is first of all you can try to reset your printer -
  • Turn the printer off with the Power button (if available).
  • Disconnect the data cable from the printer.
  • Unplug the printer's power cord for approximately 10 minutes, and then plug it back in.
  • Turn the printer back on. If this works you're done,
If it not works then try following
  • After confirming that the printer is powered on, open the paper output tray.
  • Open the top cover and wait until the print head moves to the center.
  • Open the inner cover and check that ink tanks are properly seated.
  • Properly seated
  • Press down on each ink tank until a click is heard.
  • Close the inner cover and top cover
if reset method not works for you then you go for the new logic board replacement
Best of luck
Feb 19, 2011 | Canon PIXMA® MP530 All-In-One Printer
Canon MP530 error code - "Check Printer 6500"
Hey welcome to fixya. Hope u 'll be fine
  • Properly seated
Best of luck
Kindly keep thumbs up in Rating if it is helpful,
THANKS & Keep using Fixya
Apr 06, 2010 | Canon PIXMA MP530 All-In-One InkJet...
Mp 530 Eror code 6500 check printer
Hi ,
The 6500 error code is a logic board error code. The PCI Bus error is detected by the ASCI. Sounds like it needs new logic board. but i suggest you to first of all you can try to reset your printer -
4. Properly seated
if reset method not works for you then you go for the new logic board replacement .............
Please rate your response.
Thanks,
SF
Feb 10, 2010 | Canon PIXMA MP530 All-In-One InkJet...
My printer won't print because it says the inner cover is open. How do I close it.
The inner cover is the flap that you drop down to replace inks, there's a small switch on the right inside that goes bad, you can try opening and closing a few times, but you may need a shop to replace the switch.
Dec 08, 2009 | Canon PIXMA MP530 All-In-One InkJet...
If I want to print it doesnt work, info comes "inner cover is open" what can I do?
Hi Sir, This Inner Cover is actually the plastic door which is usually opened to install or remove the ink cartridges. This door or cover must be open or not properly inserted. Try Re-inserting it and set it Firmly.
Thank you Sir, Have a nice day.
Sep 25, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Canon PIXMA 530 grinds away
I had a persistant grinding noise about 30 seconds after the printer finished printing. It's been going on about 2 months. I did one thing which seemed to work. So try opening the cover on the back of the machine by lifting upward on the gray lever in the middle of the back of the machine. Leave this cover open during and after printing. The grinding noise went away.
Jan 11, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Error is inner cover is open.
The "inner cover" can be seen if you open the paper output door, which you have to do to open the "printer cover" to get inside the machine and install the ink cartridges. The inner cover is a black bar right inside here. Push it up firmly enough , and it will snap up.
Regards,
Sai.
Mar 15, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Canon PIXMA  MP530 All-In-One InkJet Printer Logo
437 people viewed this question
Clive
Clive
old marine
old marine
Ekse
