Cameras Logo
Posted on Apr 09, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Upon startup, the screen has a message that reads: Memory Card Locked! How do I unlock it?
Tom Carson
Level 3:
  • Master 3,083 Answers
  • Posted on Apr 09, 2011
Tom Carson
Master
Level 3:
Answers
3083
Questions
0
Helped
683965
Points
8555
There is a movable plastic slide switch on the side of the memory card, and it can be moved to the lock postion. Slide it the other way to unlock it.
If it's already in the unlock position, clean the contact legs with a qtip and alcohol, or a pencil eraser.
Other than that, the memory card could be bad. Try another one, if you have one.
If nothing works, the unit may have to be serviced. Take it into a local repair shop for an estimate and assessment, or contact the manufacturer's support site.
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Cameras Master 102,366 Answers
Cameras Master
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10433373
Points
622693
You didn't specify the make and model of your camera, so I'm assuming it uses SD cards.
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Testimonial: "Thanks! You're the best..."
Memory card error message on a canon powershot A700
On an SD card there is a switch at the side which can be moved to protect the card contents (locked) or permit writing to the card (unlocked). Just move this to the unlocked position.
Card locked
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Message reads "card is locked." After
Look at the memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Upon turning on my camera the message 'lens error restart camera' appears against black screen. I've turned off the camera and have tried turning on again. Still same message. Prior to the above...
Can't help with the camera- sounds like it has a fault.
The photos, however, should be recoverable by putting the memory card into a card reader on a computer.
2answers
CARD LOCKED appears oo screen, camera wont work?
Does this camera take a memory card, separate from the built-in memory of the camera? If so, remove that memory card and look closely at all sides and edges, to make sure that there is not a read-only protection switch on it.
Many of these memory cards have tiny switches, sliders back and forth, that protect the memory from being erased.
If you slid that switch into the locked position without being aware that it is there, and without knowing that you did, then the error message makes sense.
Remove the memory card and look at it very carefully.
-a.
72helpful
Cant take photos and the LCD screen says "Memory card is locked. Slide lock to 'write' position"
I don't own this camera but My guess is your memory card is in a LOCK SETTING you need to move the memory card to unlocked " wrirte " so you memory card isn't locked.....
Step 1 remove the card from you're camera
Step 2 there is a small little side on the side of the memory chip move that to the unlock position.
step 3 insert the card and start shooting!
1helpful
8 gb card unlock on canon elph screen
it should have a slide switch on the outer casing of the card... write protection lock.
8helpful
2answers
Cannot unlock memory card for my Canon Powershot S5IS
OK take out the memory card and on the side of the card is a small switch...slide the switch to the unlock posistion and that should fix ya
!Please rate this response and help us keep this area free!
Thank You!
Top Cameras Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Camera Expert? Answer questions, earn points and help others
