A simple circuit looks at the voltage that the alternator is producing, and turns thebattery light on if it is low. The battery light indicates a battery charging problem.
Hi mail2mrsri,your problem to your battery is fast low batt.try to my advice if the cellphone fast low batt.its mean grounded or have a virus,if the cellphone got a virus its also consume the battery. you need to check up your cellphone to the technician,thanks :)
A CLICKING SOUND USUALLY MEANS LOW VOLTAGE. COULD BE LOW BATTERY,OR BAD OR DIRTY CONNECTIONS AT THE BATTERY & OR STARTER. TRY JUMP STARTING WITH GOOD JUMPER CABLES " STRONG CLAMPS & #4 CABLE " . IF THAT WORKS THE BATTERY IS LOW IF IT STARTS CHECK VOLTAGE AT THE BATTERY WHILE RUNNING. VOLTAGE SHOULD READ BETWEEN 13.90 & 14.80. IF THAT IS OK , THE ALTERNATOR IS WORKING, CHECK THE BATTERY
Ummmmm "Low battery"....... not too hard to figure out. You need to charge it for several hours. If the battery is low it WILL go out on you and during that time, the battery may recover enough to come on briefly then go off again. Please charge your battery!
