Unless you have already tried the fix on this site, please see if you can reset your dishwasher. It appears to be linked to dishwasher not being able to heat water to correct wash temperature.
3 blinks is a lamp cover error, did you make sure that the lamp cover is screwed in tight? Also check the lamp cover for deformity, there is a problem with your model where the set over heats and melts the lamp cover a little causing it not to make connection with the lamp cover switch. Let me know if you find either of these problems? If not we can troubleshoot a little further.
The 3 blinks is lamp door not closed, what it really means is the door may be warped from the heat of the lamp===the door has a plastic peg on the back that when the door is in place engages a lever just behind the door. If the door is even a little bowed=three blinks.
Engage the lever with something not metal and see if set comes on, if it does replace the door.
when i turn the printer on the light flashes amber several times, then green then repeats flashing amber, and back to green etc. turning it off and back on made no difference. last time it worked normally after being off for a couple of days, but now it is doing that again.
Amber light flashes 7 times, then green for a couple of seconds, then amber 7 times etc.
use 1000mf 25v or 35v 105 degree capacitors to replace
original four 1000mf 16v..............if new ones are a little
too high,just lay them over on board........
Look it over..........let me know......................T.
