Dell Inspiron 14 PC Notebook Logo
Posted on Apr 08, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Del inspiron 14, processor id 00426-oem-8992662-00400, processor intel (r) pentium (r), p6200 i have bought. is it duel core?
Anonymous
Level 3:
  • Master 384 Answers
  • Posted on Apr 08, 2011
Anonymous
Master
Level 3:
Answers
384
Questions
0
Helped
116796
Points
1068
Hi There.
Your processor code (P6200) is indeed, dual core. For more technical information, see the link below:
Intel Information
Thanks for using Fixya.
How to apply thermal paste to intel pentium p6200?
thermal paste,,or heatsink paste.the paste is on the processer, do not put to much on there just about a match head full in the center of the processer.
Aopen ux915g
Yes. Any Intel Pentium 4 processor will fit fine. That said A P4 processor is fast, but the Pentium D is much faster. The D stands for Dual Core. This means that they have two on die processor cores instead of just one, as the Pentium 4 does. Two processors also makes it better for "demanding" applications.
The Pentium D is better if you have a motherboard that will utilize the technology. As stated the Pentium D is Duel core. This is Intel's way of creating the closest environment of a true duel processor. The HT is for Hyper-Threading which acts like a zipper and allows several applications to process at the same time. The Pentium D will really make a difference when used with the new 64 bit operating system.
However, HT (Hyper-threading) P4, does have emulated Dual Core processing. In short, the processor makes the computer think its runing a dual core. The Pentium 4 also has a couple different levels, so if you are trying to make a comparison, make sure that you look carefully.
Although neither can match the power of an Athalon or an AMD x2 processor. If you are buying, get something with 64 bit processing. WAY faster and better for games and high graphic systems.
Im wondering if I can put th processor from my 518 in my GX280
With the flood of information you posted I can barely sift through it
Do I assume you are referring to a Dell Inspiron 518 desktop computer's, processor; to go into a Dell Optiplex GX280 desktop computer?
You know Dell is a computer company that was founded on the principle, to give the customer what they wanted; and to be able to choose from several options.
That being stated, in reality I have no idea of what Processor is in YOUR Dell Inspiron 518, or Optiplex GX280.
However, if I am to assume the specs (Specifications), shown in the following link to be true; for Your computer, then the answer is NO,
http://reviews.cnet.com/desktops/dell-inspiron-518/4505-3118_7-33186145.html
States an Intel Quad Core Q6600 processor.
(Operates at a maximum frequency rate {'Speed'} of 2.4GigaHertz.
2.4GHz )
Now let's look at the Dell Optiplex GX280 specifications,
http://reviews.cnet.com/desktops/dell-optiplex-gx280/4507-3118_7-30998912.html
Both the Inspiron 518, and the Optiplex GX280 use an LGA 775 processor socket, on the motherboard.
This is good because both the Intel Quad Core Q6600, and the Intel Pentium 4, model 540; use the LGA 775 processor socket,
http://en.wikipedia.org/wiki/Socket_T
What is Not good, is the motherboard chipset used on the Optiplex GX280, will Not support a dual core processor; much less a quad core processor.
The motherboard chipset for the Optiplex GX280 is an Intel 915G,
http://en.wikipedia.org/wiki/List_of_Intel_chipsets#Pentium_4.2FPentium_D.2FPentium_EE_chipsets
The Intel 915G chipset supports Single Core processors -> ONLY.
Intel Pentium 4, or Intel Celeron D.
Front Side Bus (FSB) support is either 533MegaHertz, or 800MHz.
The Intel Celeron D is NOT a dual core processor,
http://en.wikipedia.org/wiki/Intel_Celeron#Prescott-256
"The Intel Celeron D processor works with the Intel 845 and 865 chipset families.
The D suffix actually has no official designation, and does not indicate that these models are dual-core.
It is used simply to distinguish this line of Celeron from the previous, lower performing Northwood and Willamette series, and also from the mobile series, the Celeron M (which also uses 3xx model numbers).
Unlike the Pentium D the Celeron D is NOT a dual core processor."
The Inspiron 518 has an Intel G33 motherboard chipset,
http://reviews.cnet.com/desktops/dell-inspiron-518/4507-3118_7-33186145.html
http://en.wikipedia.org/wiki/List_of_Intel_chipsets#Core_2_chipsets
Scroll down to G33 in the left column.
Read across, and look at the headings above.
Here we see the Intel G33 motherboard chipset, supports dual core, and quad core processors.
Intel Pentium Dual Core, Intel Core 2 Duo, and Intel Core 2 Quad.
Front Side Bus (FSB) support is for processors, that have either an 800MegaHertz FSB, or 1066MHz FSB, or 1333MHz FSB.
Short answer?
If it is a dual core, or quad core Intel processor, the answer is NO.
Do you know how to find out what processor is in the Inspiron 518, and the Optiplex GX280?
1) Are the computers working, and internet ready?
No?
2) Do you know about Anti-Static Procedures, and how to read the sSpec number on the processor?
Post back in a Comment.
Regards,
joecoolvette
Installed pentium d 940 duel core. Will not boot. need solution
Assuming the new processor is compatible with your MB there are several things to check. Do you have jumpers on your MB to identify different processors? Can you get to the BIOS with the new chip installed. There are several settings in there that could affect your boot process. Lastly, is your BIOS compatible with the new processor?
3helpful
I want lan driver for Intel Pentium Dual-Core Processor E6600 3.06GHz
We need the motherboard model number and manufacturer to figure this out. Not the CPU model.
Toshiba L645-S4102 stereo mix
http://tinyurl.com/stereomixfix
Drivers, for your laptop, that re-add the stereo mix device.
1helpful
What type of dual core processor can I use for my dc7600?
The motherboard for the dc7600 has an Intel LGA775 processor socket. However, not all LGA775 processors are compatible with the motherboard. For the small form factor, the following CPUs are supported: Intel Celeron D Processors:
Intel Celeron D 331 Processor (2.66-GHz, 256K L2 cache, 533-MHz FSB) , Intel Celeron D 336 Processor (2.80-GHz, 256K L2 cache, 533-MHz FSB) , Intel Celeron D 346 Processor (3.06-GHz, 256K L2 cache, 533-MHz FSB)
Intel Pentium 4 Processors with HT Technology:
Intel Pentium 4 521 Processor (2.8-GHz, 1-MB L2 cache, 800-MHz FSB) , Intel Pentium 4 524 Processor (3.06-GHz, 1-MB L2 cache, 533-MHz FSB) , Intel Pentium 4 541 Processor (3.2-GHz, 1-MB L2 cache, 800-MHz FSB), Intel Pentium 4 620 Processor (2.8-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 630 Processor (3.0-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 631 Processor (3.0-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 640 Processor (3.2-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 641 Processor (3.2-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 650 Processor (3.4-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 651 Processor (3.4-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 661 Processor (3.6-GHz, 2-MB L2 cache, 800-MHz FSB) or
Intel Pentium D Dual Core Processors:
Intel Pentium D 805 Dual Core Processor (2.66-GHz, 2x1MB L2 cache, 533-MHz FSB), Intel Pentium D 820 Dual Core Processor (2.8-GHz, 2x1MB L2 cache, 800-MHz FSB), Intel Pentium D 915 Dual Core Processor (2.8-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 925 Dual Core Processor (3.0-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 930 Dual Core Processor (3.0-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 940 Dual Core Processor (3.2-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 945 Dual Core Processor (3.4-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 950 Dual Core Processor (3.4-GHz, 2x2MB L2 cache, 800 MHz FSB)
Unfortunately, these are old processors and I don't see any available new. Newegg.com lists a couple available as refurbished. You may be better off getting a new computer with either a Intel I3 or current AMD processor.
I wish that I had better news for you.
(do not attempt to use a CPU that your motherboard doesn't support. It probably won't boot.)
Where can I download free Pentium Dual-Core Processor E5500 2.8GHz 800MHz
i want to free sound driver & graphic card driver for intel dual core processor e5500 @ 2.8GHz
Plz plzz help me......
thanks
Can i use duel core processors inside this motherboard
Hi, I am Steve lets get you some help
the simple answer is yes
Click here for a complete list of the processors supported by your motherboard. Pentium D are all dual core processors
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
