Whirlpool 'F09' states 'overflow' meaning that it has sensed water in the bottom tray where a lot of the electronics are. That is why it will not continue- for its own safety effectively.
Have the back removed and see if there is actually water there. If so possibly a hose/connection is leaking. If not then the sensor is malfunctioning ;-0(
Good luck,
John C
F09 Error = Overflow Condition
If the Overflow contact on the pressure switch is Closed for more than 60 seconds
an Overflow condition will occur. In an Overflow condition, the Door will remain
locked, and the Drain Pump will run constantly, even if PAUSE/CANCEL is pressed
twice and the Display is cleared. Unplug the unit to service.
Potential Causes
• Check the drain hose and make sure it is not plugged or kinked
• Check Wire Harness connections to the Drain Pump, Pressure Switch, and
Central Control Unit (CCU)
• Check/ Clean Drain Pump Filter of foreign objects
• Check for Drain Pump Failure
• Check the Inlet Valve for proper shut off
• Check the Pressure switch for proper operation
