Jl Audio 500/1 Car Audio Amplifier Logo
Posted on Aug 06, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
500/1 sub amp stopped working, burnt rubber smell
My jl 500/1 sub amp just stopped working after a few years, all lights are on, if i feel the speakers while the music is up high i feel a very small vibration out of the subs, i smell a little burnt smell almost like rubber, i opened it up and i noticed a little black inside one of the 7 black clip shaped pieces attached to the inside side wall under which looks like white lithium grease(located on the opposite side where the wires connect). Im guessing this is the problem, any ideas where i should go or what i should do?
  • jrok8166 Aug 06, 2008
    hey thanks man i really appreciate you taking the time to respond, i just took it to a dealer and they sent it out to jl because there is no place near by that wanted to do it.
    Good looks
    J
Anonymous
Level 3:
  • Master 631 Answers
  • Posted on Aug 06, 2008
Anonymous
Master
Level 3:
Answers
631
Questions
Helped
237719
Points
1200
It sounds like the power supply failed. Generally when the supply fails in that amp, you have to replace all 8 of the power supply FETs and all 8 of the 47 ohm surface mount resistors. Many times, the supply fails because one or two of the output transistors have failed.
If you want to have JL repair it, you MUST go through an authorized JL dealer.
If you have a good local repair shop, they should be able to repair it.
Let me know if you have any other questions.
  • 1 more comment
  • whthonk Nov 15, 2010
    How much did JL charge you to fix this? My 500/1 just did this exactly!
  • Gilbert
    Gilbert Sep 15, 2014
    what is the exact part number of the FET transistors?
  • Jordan Honeyman Feb 16, 2019
    I have a jl 500 1 ive replaced everything but the 47 ohm surface mount resistors. I ordered them but were to small. can you give me the size or package style that will fit would be much appreciated.
JL Amp isn't powering subs and speakers
just go through ur connections man one by one ull find the prob soon.....check teminals on battery...power line to amp ....all fuses within prob area and obviously make sure u have a good ground.....really impotant.....ground is the most neglected thing people do from my experience bein a audio tech oh and if that isnt it check ur subs....stick a 9v batt on the back pos n neg of each sub n c if they pop in r out this will determine if ur subz r blown
silly as it sounds, you may want to check your EQ settings on your headunit. Things like sub volume, SLA, loudness and balance. When they replaced your battery, those old settings were lost.
1helpful
Green power light on JL Audio 500/1 but no output
Its the power transistors that would be affected by low voltage. It delivered till it finally gave up 'cos the output wattage to be generated at low voltage means more current flowing through the equipment. This high current will adversely affect all small solenoid valves & transistors and IC's. Even failure of one section of any IC is rarely detectable with the naked eye. It has to be thoroughly checked with a multi-meter to assess the damage correctly......sodeep
Jl audio 500/1 amp low ohm light at high volume
I would try running the subs in parallel. Pos to Pos Dual Voice, Neg to Neg Dual Voice. Then Run + to + stereo - to - stereo on both channels.
So you have + and - running to one channel and + and - running to the other channel.
Also your LPF filter could be set too high.
500/1 amp turns on, but small ugly bass comes out speakers
Heat sink is jacked!!! Burned it out. Replace it or send it away to get fixed.... check the pricin on it sometimes cost alot almost as much as new amp....
Jl audio 500-5
Assuming that you've confirmed that the speaker is in good working order and that the wiring isn't shorted in any way...
There are separate power supplies for the high and low amplifiers. It's possible that the one for the sub output has failed. If that's the case, the output transistors probably failed and that's what damaged the supply.
Generally, I'm willing to help people repair their amps but this is a large, complex amplifier and it should be repaired by a qualified technician.
1helpful
2answers
One of 2 subs stopped working.
ya the sub is blown or the amp channel is blown
Jl audio 12w3v4....both smoked and fried on a 500/ jl amp
Unfortunately, it sounds like the voice coils burnt up. There are places that do repair, but for these particular subs, it would be more cost efficient to replace them. I also doubt they are salable, but ebay is a magical place.....
Jl 500/1
Nine times out of ten if the amp smells burnt it usuallly is. Your best bet is to hook another amp to your system and see if you get sound.
Top Jl Audio Car Audio & Video Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Jl Audio Car Audio and Video Expert? Answer questions, earn points and help others
