Hello
The circut board thinks the door switch is open.Try unpluging machine for 3 min.The restart as normal.
Its more a control board issue then a door switch.
I appreciate your post, Josh Orenstein!
From my understanding your Frigidaire washer is displaying "PAU" and "E41". "PAU" normally displays when there is an interruption to the cycle and "E41" means the main control board thinks the door switch is open. Either code can display due to a faulty door latch assembly, door strike, or main control board. You can attempt to perform a factory reset by holding down the Start/Pause button and Select button until a signal sounds. Also review the door latch and strike to see if there is any visible damage that could cause a short within the components. If there is no visible damage you may want to consult with a technician for proper diagnosis and repair of your washer. Hope this information is helpful to some degree. -Matt
