SOURCE: Sony Camcorder tape P590HGD
YOu may be confusing HI8 with 8mm. One being analog,the other being digital, and a slight difference in form factor
SOURCE: 8mm Tape stops when rewinding
try this:
some cameras have a memory where they begin make sure the memory is off or cleared then try to rewind or try fwd to end clear memory then rewind tape...
now sometime tapes of 120 are really not recommended because of the load of tape amd ost have a tension sensor 60m is usually the best recommended
SOURCE: SONY DR TRV310 HI 8
...try to use the cleaning tape...and try to fast forward and reverse the cassette with rewinder machine...not with the camcorder...
SOURCE: transcription does not work .. foot pedal will not
Hello on the right side of unit is a switch for transcribe make sure is on the on position you are going to see on Deck A only lines on display, put your tape on Deck B is the only side that transcribes if the pedal does not respond you probably have a broken pedal here is one in a great price
http://www.tvps.com/Products/ECS-Sony-IN-75-Heavy-Duty-Foot-Pedal---Pre-Owned__ECS-PIN-75.aspx
Or if you feel better to send unit to service try this.
Send an email to [email protected] or call (800) 644-9525. Please indicate model, serial and detailed description of problem
SOURCE: Sony BM-147 transcription unit rewind/fast forward problems
Hello just get a really cheap foot pedal replacement at http://www.tvps.com/Products/ECS-Sony-IN-75-Heavy-Duty-Foot-Pedal---Pre-Owned__ECS-PIN-75.aspx
Hello unfortunately this unit don't have a erase function the only thing you can get a Microcassette eraser this eraser will help even if you decide to buy any micro or mini cassette transcriber when you used the erase function on the unit the life on the head, rewind, gears and motors get reduced by using this method if you used and eraser it erase the tape Magnets are on top and bottom eliminating the need to flip the tape allowing complete erasure on one second heare is a eraser you can buy and it is cheaper than buying other unit. http://www.tvps.com/Products/ECS-ME20-Mini--Micro-Cassette-Eraser---New__VE-ME-20.aspx
