Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
Posted on Aug 06, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Wtw6600sw whirlpool cabrio
I am getting the F1 alarm . How do I access control assembly. ksthan
  • 2 more comments
  • dbrouss Aug 11, 2008
    Whirlpool has offered to pay for the part ,but it must be installed by a certified technician. Service call and labor will run you $150 . So if you buy the part and install it yourself its about the same. Anyway, whirlpool should be doing more since this is obviously a defect.
  • MyWasherSux May 11, 2010
    Same F1 deal here. I thought this interesting... The technician came out today and replaced the
    Control Unit Assembly (Part W10104830) with a "revised" Control Unit Assembly (Part W10201186 Rev A).
    It was the opinion of the technician that the original part contained a known defect (or defects); hence a new "revised" replacement part. Part cost 143.74.
    Whirlpool should PAY for this part!!!
  • Anonymous Apr 29, 2018
    at for the part And the repairmen fee as well. What kind of BS is this, where you have to pay for a very expansive Washer and when it get's a Recall, The customer has to pay for a cheap made part that probably came from China then You have to pay for the installation of that part as well.
    B.S. Guess, I'll have to make a call to my Layer. Anyone up for a Class Action suit?
  • Anonymous Aug 05, 2018
    Yes, I agree it is BS and my husband knows how to repair it, and it didn't work because it's simply a big piece of JUNK.
Anonymous
Level 2:
Novelist:
Champion:
  • Expert 261 Answers
  • Posted on Sep 13, 2008
Anonymous
Expert
Level 2:
Novelist:
Champion:
Answers
261
Questions
0
Helped
119215
Points
471
First off I hope you have a Sears unit and second you did not pay a penny. Your F 1 error is a Primary control failure. Part W10104830 and one other do F1 and a oL code.
If you own a Sears machine you qualify for a recall under sf26-779B.
There is two parts to this call the board and a washplate
MCU part # W10201186
Washplate # W10077050
Recall will need your name and phone number and the machine model and serial number.
If you meet all of these conditions to the letter call Sears Recall at 1-800-659-7026
  • Anonymous Mar 31, 2011
    how can i contact "Sears Tech Too" ?
  • Anonymous Sep 11, 2012
    Thank you John!
What's code F1?
It Means: Primary Control Failure F then 1 flashes when there is a primary control failure. Replace the machine control assembly.
See Accessing & Removing the Electronic Assemblies.
F1 is displayed on washer wtw6600sw-wht
Hello & Welcome to FixYa
F1 error in your whirlpool cabrio indicates bad control and should be replaced to resolve the error code. However, you can contact Whirlpool as well prior to replacing the control yourself as I have seen whirlpool paying for the parts themselves just because this is known to be a common issue. Please get back to me if you have any other questions.
Kevin
What is code F1 mean on the Whilrpool Cabrio. The washer stops about 5 seconds when I first put it on.
Ok the Cabrios have alot of problems. In your owners manual there is a big page where it gives you errors codes and what to do it also givees you a diagnostic feature which helps determine the problem. This site gives you the fault codes and what to replace. F1 means primary control failure. Also sometimes when the control board is bad something else could also be wrong. Good Luck
F1 (F60-68)
See Accessing & Removing the Electronic Assemblies. F1 (F60-68)
See Accessing & Removing the Electronic Assemblies.http://www.advantagesupplyfl.com/WhirlpoolCabrioWasherFaultCodes.html
I have a Whirlpool Cabrio top load washer. When I load the clothes and start the washer and it begins to run I hear an alarm, it stops and a F1 flashes on the display. What does this mean?
F1 (F60-68)
F1 flashing on the display indicates a primary control failure.
"F then 1 flashes when there is a primary control failure. Replace the machine control assembly."
The link below lists Cabrio failre codes.
2answers
Stopping after start with F1 error
Hi
Thanks for using FixYa. Error code F1 indicates primary control failure and to resolve this you'll have to replace the machine control assembly. Yes you are right, this error should be fixed by whirlpool as its a common issue with whirlpool Cabrio washers, you can call 1-800-253-1301 whirlpool will send a tech. to fix it and pay for the part. Please rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
What does the F1 means on a whroolpool cabrio loundry washing machine
Hi
Thanks for using FixYa. Error F1 indicates primary control failure and to resolve this you’ll have to replace the machine control assembly. This error should be fixed by whirlpool as its a common issue with whirlpool Cabrio washers, you can call 1-800-253-1301 whirlpool will send a tech. to fix it and pay for the part. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
7helpful
I keep getting an F1 code when my washer starts the fill up
Hi
Thanks
Rylee
1helpful
Whirlpool Cabrio Washer : What is the F1 error code that I am getting occassionally mean?
Hi
Thanks for using FixYa. Error F1 means primary control failure and to resolve this you’ll have to replace the machine control assembly. This error should be fixed by whirlpool as its a common issue with whirlpool Cabrio washers, you can call 1-800-253-1301 whirlpool will send a tech. to fix it and pay for the part. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
What does f1 mean and can it be fixed?
F1 means Primary Control Failure.F then 1 flashes when there is a
primary control failure.Replace the machine control assembly and
see accessing and removing the Electronic Assemblies.
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
