SOURCE: Can install Print Shop 21, but when the splash
Solution
You must reinstall Microsoft .net framework.
You can do this by:
Go to the control panel
Go to add remove program select Microsoft .netframework 1.1 and remove
Also if you have the Microsoft .netframework 1.1 Hotfix select that and click remove as well.
Once both those are removed we can reinstall Microsoft .netframework from the Print Shop Install disc
You can do this by:
Insert the Print Shop Install disc
Double Click on My computer
Right Click on the Drive that contains the Print Shop Disc
Left click the open option.
Double click on the folder called Setup
Double click on the file that’s called 1033DotNetfx
This will reinstall the net framework on your computer and it should fix the issue you are having.
