Humidifiers Logo
Posted on Apr 07, 2011
Hi How do I take apart a Holmes HW1850, so I can clean the fan blades and fan chamber ?? Jeff
1 Related Answer
Anonymous
  • 82 Answers
  • Posted on Jun 29, 2009
SOURCE: how do i clean the fan blades
I am assuming a lime buildup from evaporated water. Use vinegar or drip coffee maker cleaner.
Humidifier light goes on. Fan does not work after cleaning it.
Humidifier Fan Not Working - Repair Parts - RepairClinic.com
www.repairclinic.com/RepairHelp/...Fix...Humidifier/...---/Humidifier-fa...
Most Frequent Causes for Humidifier fan not working. For the most ... If the fan blade does not spin freely, replace the blower motor. If the fan blade spins freely, ...
How to Fix a Humidifier ' HomeTips
www.hometips.com/repair-fix/humidifier-doesnt-work.html
Aug 14, 2014 - Repair humidifier problems yourself with this expert, step-by-step ...6Lubricate the fan motor bearings with a couple of drops of light oil if the ...
Troubleshoot and Repair a furnace mounted Humidifier
www.instructables.com/.../Troubleshoot-and-Repair-a-furna...
InstructablesThis instructable will explain how to diagnose and, hopefully, repair a broken ... to flow through the water panel of the humidifier and the humidifier fan turns on. .... drain line was dry, GFI was not tripped, and the fan sounded like it was going so I ... Arduino · Intel IoT · Indoor Gardening · Lighting · Sewing · Parties · Star Wars.
1helpful
How to clean fan blades on sunbeam humidifier model 1118
I picked up a Sunbeam Humidifier model 1118 for $7 (which was $7 too much) second hand. It wasn't until I got home that I noticed it was filthy-dirty inside...(dirtier than shown in the photos) the reservoir, the bottom tray, AND the fan chamber all needed major cleaning.
A quick Google search told me that the grill is "not removable", and the unit is "not user serviceable". Companies do this/say this for two reasons:
a) They want you to throw it away and buy a new one, landfills and plastic filling our oceans be darned
b) They want to protect themselves from lawsuits, should someone injure themselves servicing their product (or in this instance, cutting their fingers off on the fan blade).
Imagine if all of that design know-how was put into making the product serviceable, cleanable, and long-lasting, rather than ensuring it can't be opened or repaired by the average joe.
Me, I've opened and repaired enough gadgets to think differently.
You CAN remove the grille.
Carefully insert a series of flat-head screwdrivers between the grill and the body a few inches apart, wedging the grill edge away from the body.
There are slits in the body (see photos) that will allow you to get under the grill edge and pry it right out when enough of it has been detached from the anchoring groove.
But be gentle while you're doing it.
The Grille is plastic and flexible; it will bend, but if you use too much force you will damage either the grill or the body.
The photos also show how the grill is anchored to the body - via a groove in the grille edge.
You can put the grille back after cleaning the blades and fan chamber much the same way; pressing down, and if required: prying the side of the grill inwards with a flat head screwdriver.
Mine snapped right back into place with a bit of downward pressure.
e766f363-7859-4f48-aa12-957dce77dc74.jpgclean-fan-blades-sunbeam-humidifier-gt2v12ze2wx14lgcssczfxw0-1-2.jpgclean-fan-blades-sunbeam-humidifier-gt2v12ze2wx14lgcssczfxw0-1-3.jpgclean-fan-blades-sunbeam-humidifier-gt2v12ze2wx14lgcssczfxw0-1-4.jpgclean-fan-blades-sunbeam-humidifier-gt2v12ze2wx14lgcssczfxw0-1-5.jpg
After the humidifier runs for a few minutes it just shuts off.
You might need to clean around the heating element...
we have very hard water and calcium builds up on and around the heating element and all the surrounding parts. I take it apart and pour CPR around the element and scrub with a brush .. once you get it clean it should stay running.
Holmes HM5700 Won't reset. Screen comes up with reset and starts counting down form 450
Mine did this also so I unplugged it and took it apart and cleaned it. I used a sponge to clean all around the heating element with a mixture of white vinegar and water and also put some in the water resevoir and shook it for a few minutes and rinsed it out. It ran perfectly after I did this. It gets mineral deposit build up after a while so you might need to do this every week. There are directions on the back of the humidifer that explain this and what you should do. I hope this helped
4helpful
2answers
I have a Cool Mist V3500 humidifier. The fan
TRY POURING IN SOME WHITE DISTILLED VINEGAR AND RUNNING IT. THE VINEGAR LOOSEN UP ANY SCALE AND JUNK. AFTER RUNNING UNIT FOR AWHILE, DRAIN OUT ANY REMAINING LIQUID AND ADD DISTILLED WATER OR FILTERED WATER. RUN UNIT AGAIN. THEN DRAIN OUT ANY LIQUID. NOW THE UNIT SHOULD WORK AS NORMAL. IN THE FUTURE, TRY USING DISTILLED WATER OR FILTERED WATER.
How do i clean the fan blades on the holmes humidifier
3helpful
I can't remove the grill above the fan so I can clean the blades
I have a Holmes cool-mist One-Touch Humidifier, and you can't reach the blades to clean them, and you can't take the console apart. I finally decided to use two spray bottles and clean and them rinse the Humidifer while holding the console upside down and over a sink. The one bottle you could fill with any mild cleaner plus a lot of water to dilute the cleaner. Maybe dishwashing liquid (not the dishwasher stuff), or a little bit of ammonia, or rubbing alcohol, or vinegar. Spray that on the blades while the machine is upside down, and a lot of sooty dirt drips out. Then rinse with another spray bottle full of plain water. Leave the console upside down on a towel to drip-dry. This is also how you can clean silk flowers that collect dust.
1helpful
2answers
Reset light on holmes product hls5000 humidifier
turn knob to reset....leave 15 minutes and then turn on
How to clean up?
the best way to clean the fan blades is to take like a paint brush or some type of brush and clean it that way. there isn't a way to take that apart. if you try to it can be difficult to put back together. if you have any other questions please let me know
Top Holmes Products Humidifiers Experts
Paul Carew
ADMIN Andrew
ADMIN Andrew
Are you a Holmes Products Humidifier Expert? Answer questions, earn points and help others
