Tip & How-To about Cell Phones
Model: All Motorola; check below for exception
1. Insert an unauthorized Sim Card and turn ON your phone
2. "Enter Subsidy Code" box appear
3. Enter Unlock Code
WARNING: If one of these messages appears:
- "Contact Service Provider"
- "Tamper Alter"
- "Wait before enter special Code"
- "Contact Service"
It's because you or somebody already enter too many wrong codes, you just have to let the phone ON at these errors message (do not close the phone if V3) and after 40 minutes to 12 hours, the message " Enter Subsidy Code" will appear again.
Model: A1000 and other A series model
1. Click on the Phone icon
2. Enter **057*
3. "Locking Enter Personalization" box appear
4. Enter Unlock Code
5. Press Ok
Model: L6i & L7i (NOT L6 and L7)
1. Press and hold * key and enter 787090
2. "Menu Network" box will appear
3. Select Yes
4. Press OK
5. Will ask for code
6. Enter Unlock Code
Model: All Motorola 3G network model
1. Enter **057*
2. Enter Unlock Code
Motorola CDMA & TDMA
1. Enter 74663# [Menu] [Menu] and you will be asked for a Subsidy Code
Unlock Motorola CLIQ (SIM Unlock) 1. Reboot your Motorola CLIQ with an unaccepted SIM card in.
*If the display reads "Enter Special Code", enter the unlock code and press "OK"
*If the display does not read "Enter Special code":
2. Press and hold the * key until an entry box is displayed.
3. Type *, #, 3, 2, # and press "OK"
4. Enter your Motorola CLIQ's unlock code and press "OK."
5. Your Motorola CLIQ should now display either "Completed" or "Deleted"
Motorola MPX
2. If the phone is asking for NETWORK PIN
3. Enter the NETWORK PIN
4. If the phone is asking for SERVICE PROVIDER PIN
5. Enter the SERVICE PROVIDER PIN
6. Your phone is now unlocked
Network PUK
If the phone is asking for NETWORK PUK: Power on the phone with the original Sim Card in and wait till phone is fully powered on and you have access to menu. Enter *#**364# and press green button. You will get an error message and thereafter, you will see an Engineering Menu:
1. Select Options
2. Select GSM Test
3. Select Send AT command
4. Now you will see a new window Saying "Send AT Command"
5. Enter AT+CLCK="PN",0,"[SERVICE PROVIDER PIN or NETWORK PIN]"
6. Press send
If you get Response "0 []" phone is unlocked. If you get 1 error, then make sure you have typed the code correct and try the other code. Turn your phone off, take battery out. Put battery back in. Power on the phone and leave it for 40 minutes to 12 hours until the message "Enter NETWORK PUK" is gone. Now enter the Unlock Code and 00000000 (eight zero's) as a new password
Service Provider PUK
If the phone is asking for SERVICE PROVIDER PUK: Power on the phone with the original Sim Card in and wait till phone is fully powered on and you have access to menu. Enter *#**364# and press green button. You will get an error message and thereafter, you will see a Engineering Menu: 1. Select Options
2. Select GSM Test
6. Press send
If you get Response "0 []" phone is unlocked. If you get 1 error, then make sure you have typed the code correct and try the other code. If you do not have the original Sim Card or if the original Sim Card is not accepted because you flashed the phone with other firmware, then we cannot help you
You can get the unlock code through online..........give your IMEI number and get the unlock code for ur mobile.... i will suggest the website Unlock-Zone.com which is doing good service .....you can approach this website.
