Canon MultiPASS MP370 All-In-One InkJet Printer Logo
Posted on Apr 07, 2011
Canon MP 370 data error, unable to print and computer shown usb port unable to detect. Please advise
4 Related Answers
Anonymous
  • Posted on Aug 15, 2008
SOURCE: canon mp 150 error 5
Our pixma MP150 printer has a flashing E and flashing 5, also flashing on alarm, black ink and color ink. We have replaced the ink cartridges but nothing happens. They were empty. The printer doesnt recognize that the cartridges are there. We have tried unplugging the cords and taking the cartridges out and putting them in again. Also, it wont scan a thing either. ITs likes its frozen in the error. What can we do to fix this?
jonniewalker
Starnley Johnwells
  • 1031 Answers
  • Posted on Sep 22, 2008
SOURCE: Ckeck printer ##343
its a printer reset error press
*AF-Key = Additional Functions key = the black button with the star in a head above it.
1) Enter SERVICE MODE. (Press AF-Key, followed by "scan", "copy", "scan" -Keys)
2) Select TEST MODE (press right arrow button 13 times).
3) Hit -OK-
4) Select [8] PRINTER TEST
5) Hit -OK-
6) It'll now say "- 8-2 +" press the right arrow key once to get "- 8-3 +"
7) Hit -OK-
8) Select 0. [INK COUNT].
9) Hit -OK-
10) It should return to showing the "8: Printer Test - 8-3 +"
11) Press the [Stop/Reset]key - (black key with triangle and circle on it) - (returning to the state of 4), and then press the [ON/OFF] key.
Cleaning the print head:
At any time, DO NOT wipe the actual print head with your fingers. Use ONLY water.
-Remove print head assembly from printer.
-Remove ink tanks.
-Use running warm water, wash away the exess ink that is dried around the print head.
-Take one disposable mug, fill with hot water, drop the print head assembly in there, and let it soak for an hour, or so.
(-IF you have massaging shower head, with spray jet -function, use this to deep clean the actual print head.)
-Dry it up carefully, do not wipe actual print head, just tap gently with soft paper.
-Install ink tanks, install assembly to printer, let it settle for some time (5-30 minutes)
-Run Nozzle check, cleaning, print head alignment
hope this helps if you have further problem do let me know
pls appreciate by rating this solution
Anonymous
  • Posted on Apr 20, 2009
SOURCE: canon ir 2016 cannot/wont connect to computer via usb
I have a machine it write DOWNLOAD STANDBY.Hw may i do it.
Anonymous
  • Posted on Oct 04, 2009
SOURCE: Canon pixma mp 190 won't scan / copy and printing works!
I also have a newly purchased MP 190 that prints but will not scan at all have also tried reinstalling software.
anyone help me?? :(
Printer offline which was working earlier
My computer detected printer offline. I have just used to print some documents. So, please advise what is the problem.
3answers
Offline printing from computer
disconnect printer from computer
cancel documents in queue
if using a straight USB connection, delete all instances of printer. else remove duplicate printer icons.
reboot & reconnect printer (swap cables if not detected)
2helpful
Canon Pixma MP280 reset
i did the steps to reset canon pixma mp 280 but did not work !!
so please tell me any way to reset it because i am so needy to print a lot of things , kindly be advise that the secreen shows e 0-8 , and the printer dosn't get to zero mode when i do the steps as shown in your directions on website
1helpful
My printer Brother MF 5440-CN inject all in one is unBle print as it show unable init, machine error 4F.
Just checked a site - they suggest that you clear the purge counter, maybe this will help
3answers
My Canon printer PIXMA MP 800 cannot be3 installed with my windows xp. Help please
ARE YOU UNABLE TO INSTALL YOUR PRINTER AND OTHER DEVICE MOSTLY REASON ARE YOU HAVE NO SUITABLE DRIVER THE BEST STEP THE FIND DRIVER GO TO MY COMPUTER MANAGE, DEVICE MANAGER, PROPERTY ON DEVICE WHOSE DRIVER ARE NOT FOUND, COPY DEVICE ID CODE OPEN http://devid.info SITE AND SEARCH YOUR DRIVER AFTER SEARCHING EXTRACT YOUR DRIVER ON ANY LOCATION GO TO DEVICE MANAGER, UPDATE DRIVER SELECT PATH OF DRIVER INSTALL DRIVER TO USE THIS STEPS
2helpful
Usb not detected
Dear Sir,I m not able to found my Usb kingston 2gb in my removable storage menu when i inserted in all usb port in my laptop.this problem occured when i m cahanging and saving some data in a excel file,.it has shown me that there is no data where it has full of data that i badly need.please help me
Computer not recognizing my camera when connected
Most of the issues can be solved by either reinstalling the software or by disconnecting and reconnecting the device.
In this case we can close in on three solutions
1) The USB drive in the system is not functioning. Try connecting any other USB devices to the same USB port and check whether it works or not. If the other device works well then it could be a problem with the data cable or with the port in the camera (usually firewire)
2) The data cable used to transfer data might have become faulty.Try using another data cable if possible and still the same issue continues then try connecting another camera to the system and if the other camera gets detected then the problem must be with the camera.
3) Try connecting the same camera to another system and see whether the camera gets detected. If no, then the port in the camera is defective.
After this we can close in on which could be faulty. data cable / Computer / Camera.
Canon pixma mp160 printing problem
Here is the straight scoop for fixing your problem from the Canon website:
Issue: Unable to print from the computer when an error message is displayed
1. Configure printer driver to correct port 2. Disconnect and reconnect the USB cable to ensure a secure connection 3. Disconnect other device and reboot computer 4. Remove [Other device] from Device Manager
Hope this helps.
halthefotoguy
I want to know if I can print without USB using my wireless, I have a Canon pixma mp160.
Canon Pixma MP 160 do not support Wireless Interface
So you will need to connect it to USB port in order to print the documents
Interface
USB 2.0 Hi-Speed3
Direct Print Port
Specifications for Canon MP 160
You can refer the Canon MP 160 Manual for further inofrmation
I hope the above resolves your query
all the best
Do rate the Solution, as we can guide others accordingly
Thanks in advance
old marine
old marine
ZJ Limited
ZJ Limited
