SOURCE: I lost my nokia x2
The only thing you can do is contact your provider, and see what can be done.
Actually, the following answer of yahooanswers.com may have an answer for you:
if u have forget your security code then the code which helps you is master code
to generate master code VISIT this site
http://nfader.z-host.ru/
this site gives u all phone master codes thanks
Good luck, and hope this helps.
SOURCE: nokia 1202 phone security code problem
hi, now i need to tell you something first, their is a master unlock code for nokias now this code wont work if you have entered the code wrong more than 5 times if you have done this then the phone is hard locked and can be only unlocked using leads and software by a phone shop, how ever not all phone shops will do this any more so the phone may be of no use to you.
now the code dont work on the latest nokia's due to the firmware update nokia put into their newer phones so if the code dont work you have either entered a wrong code more than 5 times or the phone is hardlocked due to firmware software.
now i have checked your imei number and have checked it is not stolen so i can now give you your master code.
when you switch the phone on and it asks for the security code you need to enter this code 7447025165
once you enter that the security code will be removed and reset to what it was when the phone was new.
if this code dont work then the phone is hard locked and can be only unlocked using leads and unlocking software.
Testimonial: "Thank you very much for the explanation. I think i got lucky with the phone. after switching off for few hours, the security code worked. Thanks."
SOURCE: my nokia x2-00 security code
Hi, the default security code for the Nokia Cellphone is 12345. If you have changed the security code of the Cellphone, then you need to flash the Cellphone which is done by any Mobile Service Center.
