Bulova Chronograph Marine Star #96B99 watch Logo
Posted on Apr 07, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What are the functions of buttons on 98B106 - Bulova Chronograph Marine Star #96B99 watch
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on May 23, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
235
Points
Como programar la hora en 96b99
Anonymous
Level 3:
President:
  • Master 2,501 Answers
  • Posted on Apr 07, 2011
Anonymous
Master
Level 3:
President:
Answers
2501
Questions
Helped
1291838
Points
7081
I was unable to find the model 96B106 in their range but I did find 98B106. I this is the watch you have, then go to http://www.bulova.com/watches/bulova/marine-star/98b106/ and download the usermanual.
1helpful
How do I use the buttons in this QHY watch?
Hopefully, this will help...
Lego Watches Manual Instruction:
There are 4 buttons on this lego watch case, Light button, Mode button, Stop button and Reset button, now I will show how to set the time easily!
1, Light Button: Press this button, the watch LCD light will display for 3-5 seconds;
2, How to use the stopwatches chronograph function?
Answer: When the lego watches in normal working condition, Press "Stop button" for 1 time, then the watch goes into the chronograph mode, then you can use "Stop button" and "Reset button" to operate this function.
3, How to set the alarm time?
Answer: When the lego watches in normal working condition, Press "Stop button" for 2 times, then the watch goes into the alarm mode, then you can use "Stop button" and "Reset button" to set the alarm time, also you can turn off or turn on the alarm function and chime on every hour function by the same operate.
4, How to set the right watch time, hour, minute, second, week, date, month, year?
Answer: When the lego watches in normal working condition, Press "Stop button" for 3 times, then the watch goes into the time setting mode, then you can use "Stop button" and "Reset button" to set the second, minute, hour, week, date, month and year.
This is all. So now please have a try to set your lego watches time!
Dec 06, 2014 • Watches
Set date & time
mcdevito75 here, Generally you need to operate 2 buttons, to set the functions, try pressing the MODE button see the display flashing, press MODE again to see each function, when at the function you want to adjust, press SET, press MODE again to move onto next function, once all functions are set, press MODE for staedy display. If this fails, look for a small watch repair shop in your area for help.
1helpful
How do you set the time and date on model 45/6967pnkwm ijust bought it and there were no directions
mcdevito75 here, You need the MODE and SET buttons, press the mode button and see display flashing, now! press MODE again and set each function, after each function is set press MODE to move to the next function, when all functions are set, press MODE again for steady display.
8helpful
I just bought a Kenneth Cole Unlisted mens watch. There is no instructions on how to set the day and date. Is it broken out of the box or are those dials just fakes? Jens
The Mode button on the bottom left hand side will set your "SET" buttons to work.
The first push of your Mode button will activate your Stop Watch. Press the top right button to time your subject. Press it again to stop timing your subject.
Pressing the bottom right button will reset your Stop Watch to zero.
Press the Mode button to release your Stop Watch function and return to the Telling Time function.
Press the Mode button twice and you'll be able to set your Alarm function. Your Hour number will be flashing. Press the top right button to set your Alarm Hour. If you Alarm Hour is for the afternoon or evening continue pushing until a "P" appears by your hour number . This will be your afternoon/evening hour. If there is no "P" that, of course, will be your morning hour.
Press the bottom right button to adjust the minute number of your Alarm function. Your minute number will be flashing. Again, using the top right button, you'll be able to adjust your minute number.
(If you hold any number changing button for a long time, the numbers will flash through rapidly.)
Press the mode button to release your Alarm setting function.
Press the Mode button three times to set the Time of Day on your watch. At this point you'll also need to push the bottom left button to activate your Time of Day function. after pressing the bottom right button your minute number will start flashing. Press the top right button again to adjust your minute number. Once that's done, press the mode button to release your time of day function.
Hope this helps!
HOW DO YOU SET A LADIES ARMITRON ALL-SPORT WATCH WR330 OR 45/6990?
mcdevito75 here, One of the buttons should show MODE on the case of the watch, press that MODE button and see flashing, now press the set button to set time, each function you set, Time, day, date you have to pess the MODE button again to move onmto the mext function. Once all the functions are set press mode again and see a steady display.
Jun 21, 2010 • Watches
1helpful
The problem is that i simply dont have the users manual and dont understand how to manipulate my watch
mcdevioto75 here, I'll try to help, 1 of the buttons should say mode, if no button look for a in-dent naer the other buttons and push that in, or press the mode button and see the dial blinking, press set to cahnge and adjust each function, Hour, Minute etc. after each function is set press mode to mave to the next function when done with your functions, press mode to return to a staedy dial.
2answers
I cannot change the settings for the day, date
The depressing the top left buttom will move the watch between functions. Once on the function you want to chane, the bottom left button will select the group to change within that function and the bottom right button will adust the numbers. Hope this helps
6helpful
Automatic light function.
There is a button below the face of the watch that has the atomic watch symbol on it. Hold this button down until you hear a beep and it will turn that function off. To turn it back on, press & hold the same button until you hear a beep.
Top Bulova Watches Experts
ZJ Limited
ZJ Limited
NOEL
NOEL
Are you a Bulova Watch Expert? Answer questions, earn points and help others
