Our canon D1120 has started showing a series of questions.. Dept. Id, Dept Id password.. none of which has been set up for this. Now we cannot print (except spooled from the computer) and we cannot scan anymore. Any ideas?
A lot of times Windows XP installations do you have a password set for the administrator account. When you first boot up the machine, instead of trying your username and password, try using the username "Administrator" with a blank password. If that works you can go to the control panel and reset the password for your user account. Otherwise you can try using the offline NT registry editor. A great video showing its use can be found here. You can also use OPHCrack found here. Both of this have a slight risk for data loss so proceed with caution if you choose to that route. If you have any further questions about the process, let me know.
You will have to reset/clear the password. This WILL REMOVE all passwords setup in Dept ID Management. Go into Service mode by pressing the Additional Function key, then the 2 & 8 pressed at the same time, then Additional Function key again. Press COPIER on display, then Function ( across the top ), then CLEAR, PWD-CLR, Then Ok. You may also use the arrow keys on the display to get to PWD-CLR. Then the RESET key or maybe power down the equipment.
oday
I start my printer canon ir 2520 and i see dept id and password prompt
screen, I did not reset any id and password earlier, I cannot go inside
the menu or i can't take any copy. Please give solution for disable or
reset the same.
try this : press * with head press the custom setting browse it you will find to activate dept code then you need to have dept code id then password for ex.dept code id -0001 password 9999 you need to enter this two info to open the copy functions hope this will help
Dept. ID is activated that is why it is asking you to enter it. If you are not needing the function you can ask the local service provider to check the settings of your machine.
