SOURCE: back wheels will not click
I had the same problem. It was a sort of buildup which was ammazingly problematic. I undid the small screws on the inside of the wheels (1 screw per wheel). Be careful because a spring and black plastic piece will fly out. then use a screw driver to push the gray wheel removal button. You will find that it seems sort of stuck. Clean inside the plastic chamber and the slider piece...I just used my fingers. Then you will see that it slides freely. Put the sliding piece in the correct position for when the wheel is removed...button depressed. Put the wheel on. Push the sliding piece with a screw driver so that the wheel is locked and the button is popped out. Put the spring back in and the black plastic piece back....hold it on and redo the screw. The wheel should be locked on. I am not sure if you would be able to remove it and put it on again...I think so, but I am not trying since I don't usually remove the wheels anyway. I hope this works for you too! Good luck!
SOURCE: Quinny Buzz Jogger Folding System
Before you play with it any more be aware that Quinny frame has a 2 year warranty. Avoid damaging your warranty and contact the retailer.
SOURCE: How do I replace the Quinny Zap cover on the
Hi, there is an instruction manual for the Quinny Buzz over at the following link:
http://www.freebabymanuals.com/quinny/prams/Page-2
Hope that offers a solution.
SOURCE: I can not clip together
hi here are a couple of videos that may help insert the unit if you still have problems i suggest contacting quinny as the may be a fault with the wheels or frame
they should just slot in once you have pinched the two buttons this makes it easier to slot into the frame
http://www.youtube.com/user/dorelengineers#p/u/7/GUY6QO4w54Q
http://www.youtube.com/user/Kiddicare#p/search/0/X0Sk6A9nt4E
SOURCE: Where can I get spare seat adaptors from, as one
check http://www.quinny.com/ot-en/dealers for your local dealer , they should be able to help for the missing part
Removal & Installation
Did you have any luck with this? Have the same problem...
